Prius Prime 105mm Longer than Gen4 Prius
Discussion in 'Prime Main Forum (2017-2022)' started by priusfan500, Aug 27, 2016.
  1. priusfan500
    priusfan500 Member
    94
    110
    Translated from Japanese car site WebCG..
    "Wheelbase is the same 2700mm as the "Prius". From such as the need to protect the lithium ion battery at the time of rear-end collision, the rear overhang is 80mm extension in Prius ratio."
    #1 priusfan500, Aug 27, 2016
    KrPtNk likes this.
    49,632
    funky, by any measure.
  3. Tideland Prius
    16,172
    It's longer than the Prius v! (It's 165mm longer than Gen 4. 80mm is just the rear)
    Prius v: 4,630mm
    Prius Prime: 4,645mm
    #3 Tideland Prius, Aug 27, 2016
    49,632
    i don't get the point, aerodynamics?
  5. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    Thanks for finding that information. I knew that the car was a few inches longer than the liftback, but I didn't know that it was because of added protection for the battery. It makes sense, though.
    Some nice images if you go to the original website and enlarge them, including a view out of the rear window.
  6. Prius Maximus
    Prius Maximus Senior Member
    935
    785
    Northeastern IL
    #6 Prius Maximus, Aug 27, 2016
    Tideland Prius and bisco like this.
  7. bisco
    49,632
    ah, so. warthog.
  8. priusfan500
    priusfan500 Member
    94
    110
    Here's a few of those photos. It looks to me like the interior dimensions may be similar to the Gen4 with exception of the raised floor due to batteries. The carbon fibre hatch appears to have been made extra thick to account for that added length..which also means the rear bumper has a longer lift over area.. Screen Shot 2016-08-27 at 10.26.08 PM.png Screen Shot 2016-08-27 at 10.25.42 PM.png Screen Shot 2016-08-27 at 10.25.03 PM.png Screen Shot 2016-08-27 at 9.52.25 PM.png
    Tideland Prius likes this.
  9. Tideland Prius
    16,172
    Yes.
    This is interesting:
    It translates to "models with the solar panel roof will see a daily maximum of 6.1km. On average, one can expect 2.9km's worth of solar power.
    Yeah if you look at the last photo, it's definitely thicker than a Gen 4 hatch. (And the Gen 4 has plastic bits attached to the metal to give it that 3D look (it's the bulge on either side of the licence plate)
    #9 Tideland Prius, Aug 27, 2016
  10. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    Larger "crush distance" and more room for structure to protect the battery. It probably also improves aerodynamics, but that was not the original intent. Though knowing how engineers think, they probably were happy to lengthen it a bit and get the aerodynamics improvement as well. I wonder if the improvement would be measurable?
  11. bisco
    49,632
    looks like the boat tail bob w wants to add to his i-3.
  12. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I am thinking maybe some extra cargo space too to help recover what is lost.
    It looks like that raised floor has a flap/handle to raise it..any space under there?
  13. bisco
    49,632
    that would sweeten the pot.
  14. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    This is not bad (and in fact not so far from my estimations made earlier); so on good days the EV range can be increased by 10%.
    It suggests a usable battery charge close to 1 kWh, maybe 800-900 Wh for the extra battery. That could be obtained using the 1.3 kWh battery as also used in the P4, assuming 60-70% usable charge.
  15. Tideland Prius
    16,172
    Possibly but I think the length has to do with design (front) and the CF hatch (rear). The double wave read window supposedly offsets some of the lost in aerodynamic efficiency by the front end design. That might explain why the Prius Prime is listed at 0.25 Cd vs. the Gen 4's 0.24.
    Again, there is the same bin like the PiP where you can store the mobile charger, tonneau cover and other small/long items. There's also a small bin on the right side of the cargo area (similar to the left bin that we've had in the Gen 2/3)
  16. bisco
    49,632
    are we sure that's the final version?
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    Do you happen to have dimensions of that bin, or even pictures of it open?
  18. Tideland Prius
    16,172
    I didn't take any dimensions or take personal pictures (I'm kicking myself for that but I guess we'll get pics in a few months)
    Taken from here
    You'll have to really brighten the screen to see the bin on the right side before it's closed.
  19. Lee Jay
    5,850
    4,024
    Thanks. So, maybe 4-6 inches "wide" (front to back) and 6-8 inches "deep" (top to bottom), and the width of the tonneau cover?
  20. Tideland Prius
    16,172
    Probably closer to 4" front-to-back (4.5-5" is my guess). 6-8 deep sounds right.
