1. Offline
    JRMurray Magnetic Gray is the only way!
    Dec 4, 2007
    Message Count:
    Surrey, BC, Canada
    Your Vehicle Year:
    I read in this thread <http://priuschat.com/forums/prius-main-forum/38045-canadian-2008-prius-rear-disc-brakes.html> that the Canadian Prius has front discs/rear drums.
    I'm quite familiar with the benefits of rear discs on a conventional car, but do rear drums present much of a disadvantage for the Prius?
    Cheers!
    Joel
  2. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    Message Count:
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
  3. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Not really. It has ABS w/EBD and Brake Assist to help you out (assuming the brake pads are of decent grip). The tyres are ok but I don't know what the 16" alloys adorn. Probably Bridgestones if I had to guess.
    If you take a look at the rear drums of a Prius, it's probably the smallest rear drum of any car (maybe except an old Kia Spectra back in the cost-cutting days). Despite that, it stops just fine. I drove a Prius in the Toyota Hybrid Tour last May and put it through several repeated full emergency stops with some through a large puddle of water at the SilverCity Rmd parking lot. Aside from a bit of smoke and the burnt smell of rubber, it seemed ok.
    Keep in mind that the brakes aren't used very often so they're not likely to heat up too much during normal driving so smaller rotors/drums will suffice.
  4. Offline
    rookie101 average member
    Jan 27, 2008
    Message Count:
    22
    hatfield PA
    Your Vehicle Year:
    if you drive the prius correctly you will only use the conventional brakes at very low speeds.
  5. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,757
    2,806
    Northern Michigan
    Your Vehicle Year:
    Drums are not really a disadvantage on the Prius. The main advantage of disk brakes are that they resist fade during extended braking. With the Prius, the hydraulic brakes are not used for extended braking, but only at low speed or for a fast panic stop. The only exception to this would be a very long and steep downhill where the battery SOC maxes out and engine braking is insufficient to keep the car slowed. In that case, the friction brakes have to pick up the slack. This is a rather rare and specific special case.
    Tom
  6. Offline
    N3FOL New Member
    Dec 2, 2007
    Message Count:
    873
    Stewartstown, PA.
    Your Vehicle Year:
    I don't really mind having drum brakes on the rear of my Prius. Besides, I do not really go fast enough like a sports car. :rolleyes:
    My old '96 Nissan Quest had rear drums and it performed just fine. I guess it all depends how aggressive you are in your driving habits. For emegency situation, the Prius has lots of stopping power.
    Drive safe and maintain a safe distance.
  7. Offline
    Bill Merchant absit invidia
    May 3, 2005
    Message Count:
    4,096
    Your Vehicle Year:
    Which is why B mode is there...
  8. Offline
    Mar 2, 2006
    Message Count:
    17,757
    2,806
    Northern Michigan
    Your Vehicle Year:
    Exactly, although B mode doesn't eliminate the problem, it only forestalls it. If a hill is so steep that engine braking is insufficient to keep the car slowed, the friction brakes will eventually have to pick up the slack after the SOC maxes out. There is no other way to slow the car, short of driving into a tree. Admittedly, this is a rare situation that requires a long, long, and very steep hill. Being and engineer, I have to list all of the options, even if they are unlikely. In this type of situation, B mode immediately starts engine braking and wasting energy to forestall maxing the SOC. In D, the same thing happens, but not before the SOC is fairly high. B mode buys you more distance before the friction brakes become necessary.
    Side note to Bill: I know this is all old hat to you. I posted it again to help n00bs that might be reading this for the first time.
    Tom
Share This Page
