1. Offline
    mikdik New Member
    Sep 5, 2009
    Message Count:
    Your Vehicle Year:
    Is Prius Gen III regen braking either ON of OFF or is is MODULATED by varying pressures on the brake pedal? Another way of asking - if I am cruising at highway speed and take my foot off of the accelerator, kinetic energy is clearly converted to electrical energy and stored, resulting in some vehicle slow down (emulating engine compression). Now, if I PRESS LIGHTLY on the brake pedal, just enough so that I can feel in increase in deceleration, has the hybrid system INCREASED THE RATE OF REGENERATIVE BRAKING or simply added mechanical (hydraulic) brakes? If I press a little harder on the brake pedal to slow a little faster, does the rate of regeneration increase? Do the mechanical brake shoes (pucks?) literally NOT ENGAGE AT ALL as long as I keep only light to moderate pressure on the brake pedal (until I slow below 7 mph)?
  2. Offline
    yardman 49 New Member
    Mar 26, 2009
    Message Count:
    606
    68
    Northern Kentucky
    Your Vehicle Year:
    It's modulated, as far as I know But for a hard or panic stop, the friction brakes activate, even if you are above 7 mph.
  3. Offline
    Dozzer Prius Noob
    Jul 23, 2008
    Message Count:
    185
    Swansea, UK
    Your Vehicle Year:
    Yes it's fully modulated. If you want to know what's going on inside, get a hold of a Scanguage2, shows all the interesting bits going on..
  4. Offline
    hobbit New Member
    Mar 23, 2005
    Message Count:
    4,089
    443
    Bahstahn
    Your Vehicle Year:
    If it wasn't modulated by foot pressure it would feel much more
    jerky and abrupt. Watch your HSI and how the "charge" portion
    changes as you vary your foot -- that's a fairly reasonable
    representation of how much regen current is being sent to your
    battery.
    _H*
Share This Page
