Prius Sporadically Dies When I Accelerate - Codes P0303, P0420, P3191, P3125
Discussion in 'Generation 1 Prius Discussion' started by David Johnson, May 21, 2014.
  1. David Johnson
    David Johnson Junior Member
    33
    Chicago, Illinois
    2002 Prius
    I
    Ok I was trying to find a previous post I made that I thought was on this forum but I can't find it. Here is the problem that I am having. On any given day my car will cut-off when I put my car in Drive or when I accelerate as soon as I touch the gas pedal.
    I have cleaned the throttle with spray, toothbrush, and rag. Air filter is still good. I added fuel injector cleaner. None of that seems to have helped. So I noticed that I started having the problem the same day I bought gas from a different gas station (cheapest one in town). So I burned most of that gas off and went to a different gas station. Car ran great for a few days but today it cut off on me again when I stepped on the gas pedal.
    All the hybrid warning lights come on and the check engine light.
    So I had a parts store pull the error codes and here is what they came up with: P3191, P0402, P0303, P3125. I have had the car for only 3 years now and never had a tune-up. It has 150k miles on it. The P0303 codes says, "cylinder 3 misfire detected; weak or missing spark; plugged fuel injector, engine mechanical fault; Large vacuum leak specific to cylinder" The clerk said that I may need a tune up. I am hoping that if I replace the spark plugs then it will resolve the stalling issue.
  2. Patrick Wong
    18,198
    6,461
    Use the correct NGK or Denso iridium spark plugs, not some cheap substitute.
    Remove the mass air flow sensor and clean it using MAF spray cleaner. Do not use throttle body cleaner on the MAF sensor.
    You will also need to replace the catalytic converter to take care of P0420.
    If you are lucky, P3125 will go away after you get the engine to run reliably. Otherwise, you have another problem with the inverter or transaxle.
    David Johnson likes this.
  3. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Ok this Prius is working my nerves. Over a week ago I cleaned the throttle plate; then it stalled on me again; So I cleaned the MAF - stalled on me again a day later; Thought maybe I bought some bad gas so I refilled the tank with less than a 1/4 tank of gas and added a fuel cleaner. Then it ran good for a few days. But stalled again. So last night I changed the spark plugs and they looked bad. Hours later stalled again. Today, I noticed I was around a quart of oil low so I added oil, put some gas and injector cleaner in the car - stalled twice.
    It seems that it is more likely to stall when I am sitting on an incline. Car is in drive and as soon as I put any pressure on the gas pedal the gas motor shuts down. While sitting at the light some times the idle isn't always smooth. I can feel the car vibrating because of the engine (it feels like sitting on a suspended bridge). But most of the time the idle is smooth. So I am wondering if there is a way to increase the idle RPMs or is the problem the fuel filter?
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Have the coil packs been tested?
    If you have a scanner, a simple test would be to swap the coil pack from the misfiring cylinder with a different cylinder and see if the misfire follows.
    XT1049 ?
  5. bwilson4web
    15,372
    Vacuum leak via PVC hose/valve?
  6. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    My air filter was kind of dirty so I removed it and put a paper towel inside of the air filter housing. The idle seems smoother but vehicle still dies when I am on an incline and press the gas pedal. I went to another auto parts store and she hooked up the thingy to my car and said it has one code P0420. I told her that it was 4 codes before but she claims only one code was active. Not sure if she knows what she is talking about or not. But her computer stated that Code Definition: (Bank 1) Catalyst deterioration
    Possible causes:
    Base engine mechanical fault that affects one cyclinder
    Catalytic converter has failed
    Check for air leaks
    HO2S has failed; or is loose.
    But when I am driving even at high speeds the car runs smoothly. Acceleration has gotten better with new spark plugs.
    Should I remove the throttle plate and clean it more thoroughly? I thought I did a pretty good damn job.
    Any suggestions?
  7. royfrontenac
    royfrontenac Member
    247
    99
    Kingston Ontario Canada
    2001 Prius
    I replaced front and back O2 sensors and MAF sensor and replaced the gasket on the exhaust manifold connection(had a leak) to get rid of 420 code. I bought the sensors( made in china) off the internet for around $30 each and they work well for me; the front oxygen sensor was rusted and required heat to remove. Reset code when finished.
    Best of luck
    Roy from canada
  8. Patrick Wong
    18,198
    6,461
    My first suggestion is that you buy the correct engine air filter and install it. A paper towel is not an adequate substitute.
    What cleaning product did you use to clean the mass air flow sensor?
    What spark plugs did you install? Were they properly torqued to 13 ft.-lb?
    My second suggestion is that you look at the throttle body interior and throttle plate, rotating the throttle plate 90 degrees to the full open position. If you don't see any black residue, then you are good there.
    My third suggestion is that you have the fuel line pressure measured. It should be at least 43 psi. If the pressure is low, inspect the circuit opening relay. Remove it and apply 12VDC to the coil terminals. Measure resistance across the switched terminals, which should be 0.5 ohm or less using a digital multimeter. If the relay is good but the fuel pressure is still low, then the fuel tank will need to be replaced (since the fuel pump is installed within and cannot be removed.)
    My fourth suggestion is that you will need to replace the catalytic converter, but that is not the cause of the gasoline engine dying when you are on an incline and attempt to accelerate. You can start by replacing the upstream oxygen sensor first to see if that might help engine performance and that also might delay the need to replace the cc.
    My fifth suggestion is that you measure engine cylinder compression (using Mini VCI and a compression gauge) or have a cylinder leak down test performed, to see if your engine has unusual wear (which would not be surprising as it appears your engine was poorly maintained given your posts in this string.) The spec is 128 psi. No more than 14 psi difference between cylinders is acceptable, and the minimum psi is 99.
    How frequently is the engine oil/oil filter replaced?
  9. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    I change the oil around every 6000 miles. I bought npk iridium plugs but didn't use a torque wrench when installing. I cleaned the the throttle with throttle spray and the mass air flow sensor with mass air flow sensor spray. I punched the gas pedal real hard from a stopped position and the engine revved up and didn't stop so I had to turn the car off. I started it back up and it idled fine. I am taking it to the dealership because I don't have mechanical experience.
  10. C Clay
    C Clay Member
    281
    51
    Lexington, KY
    Well David... what did the dealer recommend?
  11. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Well .... Unfortunately, I have been too broke to even take it to the dealer. I am still driving it and still having the same problem. I have learned to just gradually accelerate. So I can go days and days without it cutting off. But if I am on an incline that requires more acceleration I stand a 30% chance it will die out unless the idle on the vehicle is high at that time. Several times I thought I smelled antifreeze on different days. I do notice that my temperature light stays on longer even in the hot weather it can take several minutes for the light to go out. So I am looking for a job and just hoping that the car will get me there. It still runs great and hopefully will hang in there with me until I get a check big enough for the Toyota dealership.
  12. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Ok welll...... :(
    I went to the good folks at the state Emission's office to let them test my car so that I could drive it on Illinois dangerous roads and I failed the test because a P3125 code came up. My Check Engine light wasn't on but they said it may come on - so i failed. I never took care of the other issues with the previous codes that I mentioned in this thread.
    So I was driving my car last night and learned to not accelerate from a stopped position so that I wouldn't die out. Well I began to accelerate and it felt like my parking brake was on. I pulled over and as I accelerated again it felt like I feel when trying to get out of a chair. Suddenly the Christmas lights all came on on my dashboard. The Warning Triangle of Death and the Check engine light.
    I do not have a device to read codes and I am scared to drive it anywhere after watching videos about this error code being linked to the transmission or inverter. I just got a job and was working a lot of overtime so I could save money but now I am trying to gather info about how much it will cost to fix my car or just try and find out how much is this going to cost me. I am too out of shape to work on this kind of thing on my own and lack even the slightest confidence that I can get any self-repairs on my car to be effective. Sooo anyone know how much this will cost at the dealership or a guy in the Chicago area that will fix this?
  13. C Clay
    C Clay Member
    281
    51
    Lexington, KY
    Praying for you . Surely in Chicago you have some good resources
  14. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Well not as many resources as the folks in California have. :) I am on the south side, so I may have to drive or tow it to the north side where most of the Prius mechanics are. If I take it the dealer I am sure it will be over 1000 to fix everything. Maybe another mechanic can do it all for 800 or less. Oh well I am off Monday so will take it to someone then.
    Thanks for the prayer :)
  15. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Ok so after watching some Youtube videos about the P3125 code, I am hoping that prayers were answered. :) I went and checked on the Inverter Pump to see if the pump was working and the fluid was at the Low level. So I read about using specific Pink or SLLC coolants to refill it and decided that the leftover antifreeze in my car would suffice. It was lime color but now is pink since I poured it in the resevoir. :) The doesn't feel like it has the emergency brake on now but I will drive it for 20 minutes tonight to see if this has taken care of the problem.
    I am also going to buy
  16. C Clay
    C Clay Member
    281
    51
    Lexington, KY
    Well how is the car now?
  17. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Well it is running good. The warning lights are all out and no problems. I am going to drive it to Atlanta with some hesitancy but if it it can beat around the City of Chicago and survive it should make it to Atlanta. :)
    I tried using this OBDII device with the Turbo OBDII app but it doesn't seem to work with Prius because even when I made the Check Engine Light come on the app read no codes off the OBDII device. So I just ordered this OBDII USB device so that I can monitor my vehicle.
    I am content now and just hope this car will last 2 or 3 years until I am ready for a newer vehicle.
    how is your Prius doing?
    #17 David Johnson, Sep 7, 2014
  18. stonerider
    stonerider Member
    107
    Lompoc, CA
    I would flush the inverter coolant. When you poured in "lime colored" coolant, you have contaminated the system. IIRC, the Toyota Super Long Life coolant contains special lubricating agent. I would not wait 2 or 3 years for this.
  19. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Ok so like a Braveheart I drove my car to Atlanta (11 hour drive) and car ran good going there and the check engine light came on around 6 hours into the trip. But I got there fine avg around 41 mpg at 72 mpg avg. But on the way back around 3 hours into the trip home my PS warning light came on and the red triangle of death. I hit a bump and the warning lights went off. Again around 3o minutes later the lights lit up again. I hit a bump and the lights went out. So I am thinking that maybe a part on my frontend is about to break. So I drive around 2 hours more (or much less) and the warning lights are back. But this time I hit bumps and the light doesn't go off. So I begin to exit the expressway and notice that my power steering is going and I am having a harder time turning the wheel. I get to a gas station and turn the car off and then back on and the warning light is off and the power steering is working fine. But when as I am turning the steering wheel vibrates and the warning lights are on again. So I drove it around another 6 hours like this and made it home with the lights on the entire time. I pull the codes off the car with my crappy ODB II reader and it says P0420. - something to do with the catalyst system failure. No codes about the power steering.
    So I take it the dealership to let them overcharge me for repairs but I wanted to see if the motor would cut off as I begin acceleration and of course it did. I then checked the warning codes again and no new codes. So I mention to the service department about several problems and they said it would cost $105 x 3 for them to look at each issue. So I told them to just tell me why the Check Engine light is on. I also requested they flush the Hybrid Coolant out of the car and that was quoted at $150 so I nixed that idea.
    So now I am just waiting to hear back from them after they check the Engine light.
  20. JC91006
    16,463
    8,377
    you already know it's P0420 on the check engine light. What a waste of money.
    You avoided going to the dealer all this time and now that you are there, you are not addressing the issues. But are paying to get an answer you already know. I gotta say, you are very lucky to have this car still get you from point A to point B.
