Prius towing capacity?
Discussion in 'Gen 2 Prius Main Forum' started by joerc211v, Nov 14, 2007.
  1. joerc211v
    joerc211v New Member
    I am thinking about buying a Prius but I need to know if it would be possible to two a motorcycle (occasionally)?
    My bike weighs about 550 maybe 600 tops and I would be using a really light weight trailer so all in all should be no more then 800 to 900 lbs. Would a Prius be able to handle this? I could not find any info on Toyota's web site in reference to this.
    Thanks
    Joe
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Toyota's answer is no towing. The Prius is not designed to tow anything. That said, some people have installed hitches to carry bicycles and tow very light trailers.
    Anyone else want to chime in with specific towing information?
    Tom
  3. snowdog650
    snowdog650 Member
    171
    27
    Sacramento, CA
    <div class='quotetop'>QUOTE(joerc211v @ Nov 14 2007, 12:13 PM) [snapback]539597[/snapback]</div>
    Toyota would tell you that you can't tow anything with a Prius, and many folks on here would probably tell you the same.
    I'm sure that the car can handle 1000 pounds without a real problem ... especially if you have no passengers. But I wouldn't do it. The car wasn't made for that type of duty.
    Besides ... as a fellow biker, I have to ask -- why are you towing bikes, anwyay?
    Live to ride, man ... ride to your destination, iron butt!
    DickyDck likes this.
  4. joerc211v
    I know I know but its for my non street legal track bike (2003 CBR600RR) I also have a FZ1 set up for mountain trips. I live in Florida and the roads suck!
    <div class='quotetop'>QUOTE(snowdog650 @ Nov 14 2007, 04:09 PM) [snapback]539640[/snapback]</div>
  5. darelldd
    6,057
    388
    Northern CA
    <div class='quotetop'>QUOTE(joerc211v @ Nov 14 2007, 01:13 PM) [snapback]539597[/snapback]</div>
    Joe -
    We've been through this countless times. Search around on these forums a bit and you'll find a wealth of info.
    Here's what you'll hear:
    1. Toyota says don't do it, so don't do it. Get a truck if you want to tow.
    2. I've done it, no problem.
    3. You'll void your warranty as soon as you THINK about ordering a hitch.
    4. I've towed 2,000 pounds of trailer thousands of miles and have no issues.
    You'll find that those who haven't towed will typically tell you not to do it. And that's the safe answer, obviously. You also shouldn't ever exceed the speed limit, right?. Those who HAVE towed (howdy) will likely tell you that light loads are no problem if you know what you are doing.
    <div class='quotetop'>QUOTE(snowdog650 @ Nov 14 2007, 02:09 PM) [snapback]539640[/snapback]</div>
    Hmmm. One would be compelled to ask why you own a car!
  6. qbee42
    18,058
    3,073
    Northern Michigan
    <div class='quotetop'>QUOTE(darelldd @ Nov 14 2007, 05:13 PM) [snapback]539642[/snapback]</div>
    He tows it behind his bicycle to get a better workout. :D
    Tom
  7. snowdog650
    snowdog650 Member
    171
    27
    Sacramento, CA
    <div class='quotetop'>QUOTE(darelldd @ Nov 14 2007, 01:13 PM) [snapback]539642[/snapback]</div>
    Tough to fit a child seat on the back of a BMW GS1200, hero. :rolleyes:
    priusliferox likes this.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, Toyota does not say "no" to towing, they say "not recommended". That is NOT a "no". It will not void your warranty, as it does not say it will in any Toyota produced literature (at least that I have seen). The car weights about 3000 lb, so you are limited to about 1500 lb max, trailer and load, in most jurisdictions, to be legal. Unless you add electric brakes. ;)
    If you want to add a hitch, I'd recommend having a specialist shop build you one. I think it was darylldd who reinforced one of the "available" hitches to make it reasonably strong. To see pics of it click on his website listed at the bottom of his message above (Daryl, you neglected to mention that - I'm surprised ;) ).
    From my experience with other cars of similar size and weight and from reading other's experiences with the Prius, I don't see why there would be a big problem, as long as you don't get silly re speed and load.
  9. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    81
    Camas, WA
    So it is simple then.
    1. Don't order the hitch directly from Toyota.
    2. Make sure it is a bolt on style that is easy to install.
    3. Remove the hitch and any traces of wiring harness when you take the car in for warrantee work.
    4. Enjoy!
  10. Devil's Advocate
    922
    Las Vegas, Nevada
    The short answer, Yes.
    Heaviest load towed. 1,750 pounds.
    trailer - 550lbs
    Triumph daytona 675 - 400lbs
    Kawasaki zx6r - 400lbs
    Honda RC 51 - 400lbs
    Las Vegas to Los Angelses and back - average mpg 26-29 mpg
    top speed 55. (first time that has happended on a trip to Vegas!
    (Also night time, low temp, about 70)
  11. darelldd
    6,057
    388
    Northern CA
    <div class='quotetop'>QUOTE(snowdog650 @ Nov 14 2007, 02:37 PM) [snapback]539661[/snapback]</div>
    Hey now... you don't get to call folks out for towing a motorcycle if you've got your own reasons to ever drive a car yourself. That's not ridiculing fairly!
    OK... so you think you need a car for the kid? Just ride a REAL bike, and have the kid help.
    Oh, but wait! I hear you say that your kid isn't old enough to ride yet? Still no excuse. Here's what the first five years were like:
    Whenever I'm called "hero," I like to play the part. :D And yes. I do ride more than I drive.
    <div class='quotetop'>QUOTE(Devil's Advocate @ Nov 14 2007, 05:11 PM) [snapback]539710[/snapback]</div>
    Devil here is #4 on my list above, BTW.
    <div class='quotetop'>QUOTE(David Beale @ Nov 14 2007, 02:43 PM) [snapback]539665[/snapback]</div>
    I didn't change my hitch - I changed my car. And then helped Curt re-design their hitch to keep from melting the bumper of the Prius! I definitely recommend the new Curt hitch of all the ones made for the Prius.
    linky:
    http://evnut.com/prius_hitch.htm
  12. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
  13. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    655
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    <div class='quotetop'>QUOTE(NoMoShocks @ Nov 14 2007, 03:43 PM) [snapback]539666[/snapback]</div>
    If Toyota doesn't recommend a hitch, why do they offer one? :unsure:
  14. lynnfield
    lynnfield New Member
    Indiana
    I found this hitch and installed it before visiting here, I like it better than the curt, cleaner look. They also have some other cool prius stuff for those who are interested.
  15. lynnfield
    Indiana
    I guess I could have included this link in my previous post. :confused:
    Receiver Hitch
  16. hill
    8,067
    I'd be curious if anyone could guestimate the 1,750 load on a trailer's receiver tongue (down force). About 2 weeks ago I picked up a 1,025 pound load (large 3 piece uninterrupted power supply) that I was just barely able to load into the Prius. So with my body weight, the Prius cargo/passenger total weight was 1,245 pounds. Believe me, going back over the Grape Vine was done VERY slow, in the truck lane so as not to tax the HSD. Outside temps were below 60 degrees, so that helped a lot. Braking was no problem either ... but it WAS important to allow for a whole lot more distance.
  17. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    And these kinds of workouts is why this guy can wear spandex, post the pics online and get away with it. :p
  18. frayz
    frayz Junior Member
    33
    Mobile, Al
    Hey i was wondering what everyones MPGs were with load.
    I plan on pulling about 600lbs. plus 2 passengers and a baby. :rockon:
  19. DrD
    DrD New Member
    Reston, VA
    I haul a Kendon two bike trailer with my Ducati Monster 696 (in track mode) to tracks in WV and NJ. No problems so far.
  20. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    A low of 29 and a high around 40...
    29 is open highway loaded down with camping gear, two people, and a bike rack on the back. same mileage was achieved with an 600 or so lb trailer full of items... also while towing other cars...
