1. Offline
    vicrod16 New Member
    Jul 7, 2009
    Message Count:
    Your Vehicle Year:
    Is the Prius rating for towing at all?
    I have yet to find any published info.
    Have a very small trailer, log splitter type.
    My best guess is that installing a hitch is the issue.
    Please confirm that I am only half an idiot.
    Thanks!
  2. Offline
    David Beale New Member
    Jul 24, 2006
    Message Count:
    3,459
    375
    Edmonton Alberta
    Your Vehicle Year:
    It's in your owners manual. Towing is "not recommended". Lots of people do tow with Prius with no problems. Hitches are available. The standard knowledge is to keep the towed weight below about 50% of the weight of the Prius. So 1500 lbs max. Some owners have exceeded even that with the GII model without any reported problems. Your small trailer sounds like it would not cause any problems, providing it's done properly.
    1 people like this.
  3. Offline
    lefat1 Fat Member
    Jul 8, 2007
    Message Count:
    1,461
    43
    Sunny S. Florida
    Your Vehicle Year:
    there are hitches available, towing is limited. common sense would figure somewhere around the same as 5 adults plus a little more would be fine.
    1 people like this.
  4. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    In some jurisdictions it might be illegal to tow with a Prius. This is the case in Australia. It is an offence here to exceed the towing capacity of the towing vehicle. The towing capacity of a Prius is 0kg.
  5. Online
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,977
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    I wouldn't exceed 500lbs personally, and if I chose to tow that amount of weight, I wouldn't do so w/ passengers. Simple reason being the "transmission" and brakes were not designed for the additional weight.
  6. Offline
    tochatihu New Member
    Apr 10, 2004
    Message Count:
    3,163
    345
    Kunming Yunnan China
    Your Vehicle Year:
    2001 Prius
    Accumlated experience on this matter can be tapped in the Yahoo group called priustrailers
Share This Page
