Prius v: 300,000 miles club
Discussion in 'Prius v Main Forum' started by usbseawolf2000, Feb 7, 2014.
  1. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    wow. that is a lot of driving. what do you do?
  2. longbow
    longbow Recovering SUV Owner
    62
    34
    Bayfield County, Wisconsin
    I am a regional sales rep for an insurance co....Gotta see those clients!
  3. stephensprius
    670
    226
    wow. that is just a lot of driving around. any issues with it? what about your own personal comfort? can you show pics of cars interior?
    are you going to get another prius?
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Why should he ? The one he has is just a baby ;)
  5. longbow
    62
    34
    I will definitely get another one....eventually....I am just getting this one broken in. ;)
    stephensprius, CanuckPT and SageBrush like this.
  6. PandaBear
    PandaBear Junior Member
    Sunnyvale, CA
    2014 Prius v wagon
    Based on what you described, the engine has a bad head gasket / warped cylinder head, maybe even cracked cylinder head, because you have been driving it overheated for too long.
    There is nothing that can fix this cheaply, you'll likely need to spend about $2k to rebuild the engine or find a junkyard prius that has the same engine and swap it in, likely about the same cost. Keep driving that car with this engine and you will find yourself stalled on the side of the road.
    The reason you don't find any more heat is because your engine is no longer running correctly, and heat comes from coolant heat that comes from your engine. I don't know what else the engine coolant circuit is passing through, but if it pass through anything else you can potentially cause damage to those component too if you keep driving like that. I'd find a new junkyard engine or bring it in for a rebuild as soon as possible. There should be enough crashed Prius that has working engine you can pull from all over the nation by now, and any mechanic should be able to swap engine.
    Those mechanic in a can sealer are only good for external leak (those that don't leak into cylinder), like those Saturn engine with cast porosity. It is not for head gasket.
  7. stephensprius
    670
    226
    Any updates 2FAS4U? Are you still driving the V?
    crpriusv and telmo744 like this.
  8. 2 fas 4 u
    2 fas 4 u Active Member
    320
    350
    florida
    Update: I'm back
  9. stephensprius
    670
    226
    AND? mileage updatE?
  10. SageBrush
    11,627
    2,530
    Southwest Colorado
    Hooray!
  11. 2 fas 4 u
    320
    350
    florida
    Update: 365000
    motor replaced under 50000 miles used.
    drove about 15000 everything seems fine.
  12. SageBrush
    11,627
    2,530
    Southwest Colorado
    Any details you care to provide about the motor replacement would be most interesting.
    Estela13 and telmo744 like this.
  13. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    It's been a while since I checked in - how y'all doing? (practicing my southern accent)
    Hmmmm, I wonder if his motor came from my car? Unlikely, but funny if it did! Totaled at under 25k miles, but entire front end was good including ICE and CVT.
  14. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Whoa! Awesome.
  15. 2 fas 4 u
    320
    350
    florida
    Have a problem developing. Car appears to be misfiring while driving ease off a little car begins to shudder or shake.
    Also on occasion when I'm at a stop the engine will turn on on but not register with light showing just as if i pressed the gas while in park. Very strange happened about 5 times.
    i replaced all spark plugs still has problem. Did not mess with coils.
    engine will run for about 5 sec an shut off.
  16. JC91006
    16,470
    8,383
    Is this what killed the last engine?
  17. SageBrush
    11,627
    2,530
    Southwest Colorado
    Error codes ?
  18. 2 fas 4 u
    320
    350
    florida
  19. telmo744
    telmo744 HSD fanatic
    2,168
    764
    Portugal
    The new engine appears to be doing check idle ceremony more often, that is?
  20. 2 fas 4 u
    320
    350
    florida
    At toyota tech is claiming inverter disc dampening is bad which is causing the vibration or stutter. He says he has to remove trans cost of 12 hours would be 2700.00, he is also claiming that any misfire would throw a code. Which my car is not giving a code.
