1. Offline
    lonelymango New Member
    Start a Conversation
    May 27, 2012
    17
    New Jersey
    Your Vehicle Year:
    I've recently noticed that my v's auto dimming rear view mirror has stopped working, or at least appears that way. I'm not sure if it's because of the tint because I have used my iPhones led to test it by shining the light from inside of the vehicle but it still fails to dim.
    Just wondering if anyone else had this problem. I have less than 3000 miles on the v but I wanted to know if anyone has resolved this before I take it in for service which may result in taking half a day without my v. This mirror was great when it worked.
  2. Online
    rogerv Senior Member
    Dec 10, 2008
    1,052
    194
    Simi Valley, California
    Your Vehicle Year:
    No offense, but is it turned on?
  3. Offline
    Cap'n Junior Member
    May 4, 2012
    33
    TX
    Your Vehicle Year:
    That's an excellent question / suggestion. They're easy to unknowingly turn off when you reach up to adjust the mirror. Many's the time ...
  4. Offline
    May 27, 2012
    17
    New Jersey
    Your Vehicle Year:
    none taken. yes, i've turned the mirror off (no green light) and on (green light) and still, no dimming.
  5. Offline
    RRxing Active Member
    Jul 7, 2009
    584
    202
    Long Island, NY
    Your Vehicle Year:
    If the v has the same mirror as the 2010, then you probably won't see much if any dimming compared to other vehicle makes or models. On the Gen III hatchbacks (I can't speak for the c or v) the spoiler blocks most of the light hitting the sensor on the mirror unless its adjusted just so. I've had my car for three years and I don't even notice the dimming anymore. Should it work better? Yes. Is it a deal breaker? Absolutely not.
  6. Offline
    st-bob Hi-miler
    Dec 22, 2010
    Massachusetts
    Your Vehicle Year:
    To test the auto-dimming mirror, cover the front light sensor with a black piece of cloth, cardboard, business card etc. In the daytime, the mirror should begin dimming but only when the headlight are on (unless you've done an after-market install).
Share This Page
