Prius v Base: first encounter with strange clicking noise while braking
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Cristino, Jun 4, 2013.
  1. Cristino
    Cristino Junior Member
    46
    24
    Bayamon, Puerto RIco
    Hello,
    This morning I went thru a known rough patch on the road and was applying light pressure on the brakes as usual (EV doing about 20 mph). Once the wheels started bumping, a loss of deceleration occurred as expected but what I did not expect was a fairly fast clicking sound (about 30Hz). I *believe* it sounded like the click that is heard when the traction battery is engaged in READY mode, but I'm not completely sure. I have no idea where it came from since I was using the A/C and ragchewing on the ham radio. The clicking subsided once I lifted the foot from the brake pedal and reapplied the brakes. No indicator lights came on and the car continued behaving normally.
    I'll try to replicate the problem tomorrow, also will make sure to mention it to my dealer on the next service checkup.
  2. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Could be the ABS brake function kicking in - it's known to do this while braking over bumps, and not isolated to Prius or Toyota, but many cars in general.
  3. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    It sounds like the ABS system working. When the wheels or tires does not contact the ground and causes the wheels to lock up while braking, the ABS starts to kick in. I have noticed this numerous times in bumps and rough surfaces. I'm just glad to know that it works as intended.
  4. Cristino
    46
    24
    Thank you jhinsc and ImeanGreen for your answers. I tried to replicate the 'problem' but no luck. Being that this is my first car with ABS I suppose that is a new noise I have to learn to ignore. :)
