PRIUS v (lowercase v) FRONT Shock Absorbers sound
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ahmad ashfaq, Dec 1, 2015.
  1. ahmad ashfaq
    ahmad ashfaq Junior Member
    57
    islamabad islamabad
    2011 Prius Alpha
    Dear Folks ,
    The prius alpha i own has this rattling noise when the steering is turned left or right .
    A local mechanic advised to lubricate the opening on the top of shocks , I couldn't find the Lube spray by Liquor Moli or 3M liquid Grease .I tried a spray by WD-40 Specialist Water Resistant Silicone Lubricant, but no result .
    I have this Grease (attached pic).(desperate measure)
    Shall i apply this ?
    And how ?
    thanks
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Silly advice
    Nope.
  3. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Thanks
    Any Advice how to address this issue?
  4. Air_Boss
    Air_Boss Senior Member
    3,913
    1,068
    New Yawk
    Check the shock tube appearance for leaks, but the chattering is more likely a case of (take your choice of) worn sway/stabilizer bar bushings or links, worn tie rod ends, worn steering shaft/intermediate shaft bushing,
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    "Assuming" the problem is the shock/strut mounts, greasing them up will not fix the problem. The key is to first definitively isolate where the noise is coming from before addressing it.
    ahmad ashfaq likes this.
  6. Air_Boss
    3,913
    1,068
    New Yawk
    As suggested, first isolate the noise source. Have an associate listen while you work the steering and suspension , or vice versa.
    A number of 'usual suspects'/likely noise sources appear above.
    Based on the source, different mitigation approaches apply.
    From your sig, are you hearing this noise on a 2015? If so, task your dealer with warranty work.
    #6 Air_Boss, Dec 10, 2015
  7. Umar Muslim
    Umar Muslim Junior Member
    22
    Lahore, Pakistan
    2011 Prius Alpha
    Ahmad bhai
    Im a Prius Importer in Lahore
    i think i understand the issue
    kindly send me ur contact # on my email
    [email protected]
    we can talk over the phone
    Peace
