1. Offline
    runukraine New Member
    Start a Conversation
    Oct 26, 2011
    34
    CA
    Your Vehicle Year:
    The manual lists a ton of personalized settings that either you or the dealer can set. Problem is, I can't find in the manual where it describes how to set these personalized settings.
    After bouncing around briefly in these forums, I found that you can set the smart door unlock so that it unlocks all doors instead of just the drivers side.
    It's pretty easy. You just get close to the car and hold lock and unlock down for about 5 seconds on your key fob. After 5 seconds you will hear two beeps. Two beeps means that all the doors unlock now when you use the smart door. Three beeps means only the drivers side door opens.
    One of those simple things that makes life better.
    Anyone know how to set any other personalized settings?
    4 people like this.
  2. Offline
    rsuplido New Member
    Oct 29, 2011
    WV
    Your Vehicle Year:
    Double press on the fob opens all doors as well.
  3. Offline
    pvogel '05 Five & '12 v
    Dec 9, 2007
    87
    25
    Santa Clara, CA
    Your Vehicle Year:
    Page 538 or so of the manual shows all the customizable settings, most are settable from the nav system, go to setup>Vehicle Customization>custom settings
    Peter+
    2 people like this.
  4. Offline
    Oct 26, 2011
    34
    CA
    Your Vehicle Year:
    Peter,
    Do you have the Premium HDD Navigation on the v Five? Or do you have the Display Audio on the v Three?
    I have a v Three and there is no Vehicle Customization button on my setup screen
    Edit
    So I went to my car and turned it on and hit settings. Vehicle customization button was there. If you have the car turned on completely the vehicle button is there. If you have the battery on just for radio, the button is not there.
    So now I've set headlight shutoff to 0 seconds and set the smart door to open all doors with one touch on the handle.
  5. Offline
    DianneWhitmire High PRIUStess
    Oct 23, 2007
    3,235
    714
    Laguna Niguel, CA
    Your Vehicle Year:
    Peter's car is the Advanced Tech one. Your v THREE doesn't have his settings.
  6. Offline
    jcl410 New Member
    Oct 15, 2011
    Maryland
    Your Vehicle Year:
    OK; Call me dense... Where in the (huge) manual is that described? I couldn't find it! (BTW - I have a trim 3, and am looking for the SKS system to unlock all 4 doors when I grab the driver's handle.)
    Aloha,
    John
  7. Offline
    Oct 26, 2011
    34
    CA
    Your Vehicle Year:
    Found it in the forums here relating to another Prius model. Figured I would give it a try and lo and behold it works. Love opening all four doors by just grabbing the handle and not fiddling with the keys!
    Just get close to the door and hold down lock and unlock on the key fob at the same time until you hear the two beeps. From then on, wonderfullness...
    I skimmed the manual, so I can't say it's not there...
  8. Offline
    Dec 9, 2007
    87
    25
    Santa Clara, CA
    Your Vehicle Year:
    The guide on page 538 says what page the customization is actually described if I recall correctly.
    Peter+
  9. Offline
    Prius_zero New Member
    Jul 2, 2008
    17
    Louisiana
    Your Vehicle Year:
    Thanks for the tips. Got my four doors unlock mod. It's one thing I miss coming from my 08 prius.
  10. Offline
    Lngbrdr New Member
    Nov 29, 2011
    Rocklin, CA
    Your Vehicle Year:
    Actuallly it doesnt. :confused: The Vehicle manual says that you can program certian functions with the NAV System but doesnt explain how. It says to look at the nav manual for programming info. The Nav manual says nothing about how to customize these settings and says for an explanation look in the vehicle manual.:mad:
  11. Offline
    Chazz8 Gadget Lover
    Sep 19, 2008
    350
    66
    Central New York
    Your Vehicle Year:
    From page 124 of the Nav. System owner's manual:
    Step1 press setup
    Step2 touch Vehicle
    Step3 touch Vehicle customization
    Step4 touch the desired items to be set
    - For a list of the setting that can be changed, refer to Owner's manual.
    Step5 After changing the settings, touch "save". ...
    And here is a link to that section of the Owner's manual. Note the three rightmost narrow columns. Read first page of link to see how the columns show what settings can only be done by the dealer (or ScanGuage if you play with the on-board diagnostics (OBD) toys).
    http://www.toyota.com/t3Portal/document/om/OM47674U/pdf/sec_06-02.pdf
  12. Offline
    rjparker Member
    Jun 6, 2008
    344
    38
    Texas Hill Country
    Your Vehicle Year:
    Smart Key Unlock Option
    Worked for me. Thanks!
  13. Offline
    nieciez New Member
    Mar 16, 2012
    Virginia
    Your Vehicle Year:
    Thanks for the tip....I can't wait to change mine...thought I would have to ask the dealer to do it.
  14. Offline
    Harry Pottar New Member
    Mar 4, 2012
    22
    MA
    Your Vehicle Year:
    Just thought I would chime in here it might be obvious to most but I thought I would state it anyway. The reason only the driver door opens by default is safety. Lets say your wife is parked in a car lot at night, she opens the door she wants to make sure the others doors don't open as well. Call me paranoid but I like that safety feature stops some one rushing the car and getting in the other side.
    It only takes two quick clicks of the remote to open all the doors if you out with family and friends.
    Just my 2 cents
    paranoid
  15. Offline
    blane Carmudgeon
    Apr 10, 2012
    25
    Suburb NW of NYC
    Your Vehicle Year:
    I was searching for the same solution for my regular 2011 Prius (non-v). It worked like a charm. Thank you if you are still following this thread.
  16. Offline
    joeruo New Member
    Apr 30, 2012
    25
    boston ma
    Your Vehicle Year:
    Son of a gun, it worked. Thanks for the tip
  17. Offline
    joeruo New Member
    Apr 30, 2012
    25
    boston ma
    Your Vehicle Year:
    Thanks for that tip. I didnt think i had that option
  18. Offline
    owayneo New Member
    Jul 1, 2012
    Your Vehicle Year:
    This blog has been so helpful in so many ways. Thanks for the locks trick. Thought it was only possible in the V5.
    Wayne
  19. Offline
    Chazz8 Gadget Lover
    Sep 19, 2008
    350
    66
    Central New York
    Your Vehicle Year:
    rjparker and joeruo look like they have prius v (wagon) 3s and posted that they got the procedure to work. See their posts above.
Share This Page
