Prius won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Enoblk, May 1, 2016.
  1. Enoblk
    Enoblk Junior Member
    36
    Oregon
    I replaced the hybrid control ECU that had it immobile for the past year or so. Drove it around for about 30 minutes and realized a tie rod was bent and put it in the shop, came out the next morning and nothing in the car would work except for lights and thing that work with the car off.
    When I go to start the car the start button light is off and pressing it does nothing.
    Charged the battery
    unplugged it for 5 minutes
    Checked most of the fuses
    Tested the battery
  2. Enoblk
    36
    Oregon
    I was checking the battery for a parasitic drain and accidentally checked the voltage between the negative cable and the negative post and it was around 9 volts, i am not sure if that's normal
    48,943
    me neither. how about the voltage between positive and negative with everything off, a few hours after charging?
    also check the connection from battery negative to ground.
  4. Enoblk
    36
    Oregon
    The voltage between positive and negative was about 12.7 volts
    And there was a drain of 500ma that goes away by pulling the dome fuse
  5. bisco
    48,943
    does the dome light work?
  6. Enoblk
    36
    Oregon
    Ya dome lights and headlights work
  7. bisco
    48,943
    did you talk to the shoppe guys? did they drive it out, or was it dead inside when they were done?
  8. Enoblk
    36
    Oregon
    It hasn't been to a mechanic in several years, I've been working on it myself
  9. bisco
    48,943
    sorry, when you said put it in the shop, i thought you meant somewhere else.
  10. Enoblk
    36
    Oregon
    Nope, drove it around, it would start and shut off when I wanted it to. Put it in our shop, came out the next morning and it wouldn't start
  11. bisco
    48,943
    could someone have disengaged the safety plug?
  12. Enoblk
    36
    Oregon
    No, and the MFD would still turn on if it was, all the electronics that start before it says ready run off the 12v
  13. bisco
    48,943
    any possibility something wasn't connected tightly in the edu you worked on?
  14. Enoblk
    36
    Oregon
    Checked the connections last night
  15. bisco
    48,943
  16. Patrick Wong
    18,198
    6,464
    The voltage should be zero. Measure the resistance of the cable when disconnected.
  17. Enoblk
    36
    Oregon
    0.1 ohms resistance on the 4in negative cable
  18. Enoblk
    36
    Oregon
    Changed the newer steering control module back to the old one and started up
    Andyprius1 likes this.
  19. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Here's my guess: When you put the voltmeter in series with the negative cable, you basically put a very high resistance in the circuit and were measuring the voltage drop across it. The "parasitic load" was trying to complete its path through the tens of thousands of ohms of the voltmeter, rather than the near zero ohms of the ammeter. The total voltage drop in the circuit must equal the battery voltage, so the electronic loads in the car were only getting about three volts, and only a fraction of a milliamp was flowing.
  20. bisco
    48,943
    exactly what i was thinking.:cautious:
