PriusChat Glossary
Discussion in 'Newbie Forum' started by Tideland Prius, Sep 17, 2007.
  1. AceDeuceCoupe
    AceDeuceCoupe Junior Member
    35
    LA
    What is "spoofing"?
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    As in "fooling", to spoof the control unit by feeding it a false signal or current from an electronic sensor.
    Example: Spoof the engine coolant sensor signal wire to make the ECU think the engine is fully warmed up when it is actually at a lower temperature.
    SCH-I535
  3. JerryCS
    JerryCS Prius camper with trailer hitch
    76
    Elk Rapids, MI
    Where is a list of the Prius models available, by year? I'm not finding it, but it must be here. I'd like to know the differences. Basics like this should be easy to find.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    There's sorta of a list at Prius Wiki.
    What do you what to know?
  5. Tideland Prius
    16,064
  6. Craig Poff
    Craig Poff New Member
    Beaufort, South Carolina
    It also has a camera facing the driver to determine if the driver is paying attention when the computer detects an obstacle ahead and will warn the driver of the obstacle.
    **Isn't that what our WIVES are for?? :)
    RCO likes this.
  7. XiaoBai
    XiaoBai New Member
    Singapore
    2015 Chevy Volt
    Oil change interval I think!?
  8. alexgrigori
    alexgrigori Active Member
    163
    108
    Technology
    pls add
    ATF - Automatic transmission fluid is the fluid used in vehicles with self shifting or automatic transmissions.
    DCT - Dual clutch transmission, a vehicle technology which allows gears to be selected in fully manual or automatic mode
    OBD - On-board diagnostics, an electronics self diagnostic system, typically used in automotive applications
    TNGA - The Toyota New Global Architecture are modular unibody automobile platforms that will underpin various Toyota and Lexus models starting with the fourth generation Toyota Prius
    #48 alexgrigori, Oct 20, 2016
  9. Tideland Prius
    16,064
  10. alexgrigori
    163
    108
    Technology
    CHAdeMO - is an abbreviation of "CHArge de MOve", equivalent to "move using charge" or "move by charge". The name is also a pun drawn from O cha demo ikaga desuka in Japanese, translating to English as "How about some tea?", referring to the time it would take to charge a car. :)
    RCO likes this.
  11. Tideland Prius
    16,064
  12. alexgrigori
    163
    108
    Technology
    LRR - Low rolling resistance tires minimize wasted energy as a tire rolls, thereby decreasing required rolling effort — and in the case of automotive applications, improving vehicle fuel efficiency.
    Tideland Prius likes this.
  13. priusthetic
    priusthetic Junior Member
    Southern CA
    2014 Prius Plug-in
    Wow, this is incredibly helpful. Thank you!
  14. Tideland Prius
    16,064
    You're welcome!
  15. mikefocke
    3,636
    1,624
    Sanford, NC
    Add OCC Oil Catch Can please
  16. Tideland Prius
    16,064
    Done
  17. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Here's one from UK (Mil) SNAFU = situation normal, all 'fouled' up!
  18. mikefocke
    3,636
    1,624
    Sanford, NC
    Maybe add PIM and PIIPM - Prius Inverter Intelligent Power Module
  19. Tideland Prius
    16,064
  20. mikefocke
    3,636
    1,624
    Sanford, NC
    Maybe add BITOG - "Bob is the oil guy" forum about lubrication
