1. Offline
    marzprius New Member
    Start a Conversation
    Oct 11, 2007
    91
    Northcoast
    Your Vehicle Year:
    Gen III has a clear instant mpg bar graph display just to the right of the speedo # .
  2. Offline
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    6,272
    989
    Charlotte, NC
    Your Vehicle Year:
    Sorry, I should have been more clear. There is now an instant MPG readout in numerical form. The 3G Prius only has the 0-100 bar, which I will actually miss. Another note - the instant MPG readout only goes up to 99.9 if I remember correctly.
    It is so difficult to glide in the 3rd Generation Prius, and likewise in the Prius v, so a light showing when the ICE is off is much more useful. The only decent way to glide in the 3G Prius is to put the car in neutral.
  3. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,476
    1,812
    Queens, NY
    Your Vehicle Year:
    I LOVE the new dash display with the use of more colors. It is so much easier to read the information.
  4. Offline
    Russell Frost the priusownersgroup.com guy
    Apr 25, 2005
    123
    65
    Lancaster, Penna
    If you're going to invoke my name
    Danny wrote,
    Another new Prius, another new instrument cluster. What Toyota calls the "Combination Meter" has been moved to the center of the dash, which elicits different responses. I personally like it, but my co-driver for the day, What Drives Us' Russell Frost couldn't stand it.
    That's not exactly what I said. What I said, repeatedly, was that I didn't like it but I wasn't sure if that was merely being used to driver centered positioning in my two Prii or that I just didn't like the center positioning.
    I tend to think that I prefer it to be in front of the person most concerned with the information being presented there. At first glance, which is really all these "First Drive" events provide, it seemed awkward. Either way, I could deal with it. And the new display sort of makes up for it to an extent.
    One other thing, and it doesn't involve something I said (luckily).
    Danny wrote,
    The GreenEdge Technology system from JBL includes a new amplifier that puts out 600 equivalent watts of power, but only uses 120 watts. It weighs one-third less than the current Prius system, and reduces power consumption by 50%.
    I don't believe that's actually correct though I understand why you would post it. As I tried to detail in my review of the v (review whoring link), JBL is playing a somewhat disingenuous game here with numbers. The system is rated at "600 equivalent watts". That's five - 120 "equivalent" watt channels. As an aside, please note, there are eight speakers which means the bass speakers are tied into and sharing one channel. Anyway, your mistake is substituting 120 watts (the per channel equivalent rating) for the total output. JBL or Toyota never says this. What neither JBL or Toyota actually say is what the real wattage rating of the amp is*. I've sent them an email asking to clarify the issue, so far, no response. My guess from seeing the components in a JBL presentation case at the First Drive is what they have done is actually much simpler. I suspect, and I'm willing to bet this is the case or very close to it, design speakers that are much more efficient than previous Prius sound systems thus allowing them to utilize an amp that is much smaller and still achieve SPL's the same or higher. This is an old, old trick and Bose has done this for years. Bose is also famous for avoiding standard speaker conventions and designing speaking with a lower impedance so that the "effective" power of the amp is increased. Lower wattage, more SPL. Same story.
    And there's nothing inherently wrong with this depending on how exactly the whole thing is put together. Lighter, more responsive speakers do require less power and scaling back the amp saves electricity and generates less heat. The potential downside is that lower impedance speakers often shred amps more quickly. Using speakers with lighter cones and voice coils and smaller magnets means you get more sound with less power. It also means they can handle less power and may possibly wear out sooner. There's a reason for those "standard speaker conventions" I mentioned above. I'm also not a big fan of "digital" amps as I think they color and compress the sound from the system and tend to be built less robustly than other designs.
    Taking all that into consideration, as I said in my review, I do think the sound of the system is very good (with some idiosyncrasies noted). And if it turns out that this GreenEdge delivers on the promises it makes and holds up over time then it justifies itself.
    Of course, I still loathe marketing it using a phrase such as "equivalent watts". It's horrible but I understand why they use. I just don't like it.
    *From carefully looking at all the JBL materials in the press kit if I had to guess my guess would that this is a 20-30 watt per channel amp, maybe smaller depending on the actual impedance of the speakers.
    2 people like this.
  5. Offline
    Apr 25, 2005
    123
    65
    Lancaster, Penna
    How about a little balance
    By the way, dude, great review. Your attention to detail is impressive and you added in a couple of quotes that I had thought about including but did not. Nice job.
    Now if you only had a series of videos demonstrating everything you wrote about...
  6. Offline
    Sep 22, 2004
    11,476
    1,812
    Queens, NY
    Your Vehicle Year:
    GreenEdge seems to be good stuff. Both Mercedes-Benz and BMW sound system also have this technology.
  7. Offline
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    Jul 18, 2009
    2,144
    391
    Maine
    Your Vehicle Year:
    Did the change from the horizontal HSI to vertical make it easier to see the no-regen-no-gas state? I find on my 2010 that the combination of monochrome and the slight diagonal on the regen/EV separator makes it harder to see when you're at the right point.
  8. Offline
    Sep 22, 2004
    11,476
    1,812
    Queens, NY
    Your Vehicle Year:
    I was doing some comparison with Jetta SportWagen TDI auto and found these interesting stats:
    • Fuel Economy: 44/42/40 MPG vs. 29/33/39 MPG (auto). Prius v gets 9 more combined MPG.
    • Fuel: You can use regular gas with Prius v (premium is not required) vs. Diesel. Diesel is 30 cents more expensive than regular gas around here.
    • Engine Oil: 4.0 quart vs. 5.8 quart. Prius v has the same 1.8 liter gas engine so it should have the same 10k miles interval. It seems the Jetta TDI's OCI is also 10k miles.
    • Weight: 3,274 lbs vs. 3,285. Prius v (hybrid) is actually lighter than Jetta SportWagon TDI (single engine)!
    • Ground Clearance: 5.7 inch vs. 5.4 inch. Prius v has more clearance, great for snow.
    • EPA Passenger Volume: 97.2 vs 91.7 cu.ft. Prius v has more passenger space.
    • EPA Cargo Volume: 34.3/40.2/67.3 vs. 32.8/66.9 cu.ft. Prius v has more cargo volume with the seat up/slided forward or folded down. Jetta SportWagen's rear seat can't slide.
    4 people like this.
  9. Offline
    zenMachine Just another Onionhead
    Mar 3, 2007
    3,354
    285
    Your Vehicle Year:
    1 people like this.
  10. Offline
    Sep 22, 2004
    11,476
    1,812
    Queens, NY
    Your Vehicle Year:
    GreenEdge amp appears to be more efficient than the best aftermarket Alpine PDX amp and JL Audio HD series. I hope it sounds as good as those.
    Majority of the energy saving should be in the amp.
  11. Offline
    Apr 13, 2004
    15,053
    580
    South Puget Sound, WA
    Your Vehicle Year:
    hmmm, you think so? i personally think that the instrumentation on Gen 3 is simply better giving us the perception that glide is not available.
    if you just consider how the car drives, i think the better conclusion is that the Gen 2 simply did not report info as accurately
  12. Offline
    Sep 22, 2004
    11,476
    1,812
    Queens, NY
    Your Vehicle Year:
    I just realized that Prius v actually has higher city EPA MPG than CT200h.
    44/42/40 (City/Combined/Highway) for Prius v. 43/42/40 for the CT200h.
    1 people like this.
  13. Offline
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    6,272
    989
    Charlotte, NC
    Your Vehicle Year:
    I personally can't feel it in the pedal. I had a better relationship with the pedal in my 2006 :)
  14. Offline
    Apr 13, 2004
    15,053
    580
    Your Vehicle Year:
    that is true. on my 06 i could tell when engine was off at lower speeds, but does that mean that stealth is tougher in the 2010 or was one of the selling points for the 2010 was smoother and quieter engine and transitions?
  15. Offline
    • Moderator
    27,762
    1,327
    Your Vehicle Year:
    Not that I know but expect a similar setup up with a base model with two or three packages (w/ JBL upgrade, with LED upgrade and the AT package are my guesses).
    With the premium expected, I hope it doesn't top $40k. $30-$38k would be nice but even at $38k, you can get a really nice Sienna for that coin (SE V6 8-Pass for $36,600 or an XLE FWD 7-Pass for $38,700)
  16. Offline
    fredthepostman New Member
    Jan 7, 2009
    421
    boothwyn pa
    Your Vehicle Year:
    How much do I have to spend to get the moon roof ? I understand that the fewer packages offered, the cheaper Toyota can offer a car. Is there any chance Toyota would offer the moon roof without having to purchase the "Kitchen Sink" ?
  17. Offline
    • Moderator
    27,762
    1,327
    Your Vehicle Year:
    Maybe later on in its life but to start, nope.
    1 people like this.
  18. Offline
    Jan 7, 2009
    421
    boothwyn pa
    Your Vehicle Year:
    My plan is to purchase the car at some point next summer. My chances don't sound good but like you said, "Maybe".
  19. Offline
    bruceha_2000 Senior Member
    Jan 2, 2004
    2,686
    43
    South Burlington, VT
    Your Vehicle Year:
    Re: If you're going to invoke my name
    Looks like they are still working on things, improving some and AGAIN making others worse.
    I agree, the speedo should be IN FRONT of the driver and it SHOULD be ABOVE the steering wheel, as in the Prius Gen II and III. I HATED having to look through my hands and the steering wheel while driving my Dad's Acura TL last week. BAD ergonomics. One should NOT have to look to the side to see their speed. Gear position? OK Fuel gauge? OK, you rarely need to look at those anyway.. Nothing the driver NEEDS to look at should be other than DIRECTLY in front of him/her. The REAL reason to do it this way is so there are fewer things the manufacturer has to change for right and left hand drive cars. It is BAD for ergonomics and safety.
    They moved the shifter back to the dash HOORAY!!! And they dropped the arch. HOORAY!!! Now cut it off in front, ala the Gen II so it isn't in the way of my right leg. Is there still a "can't reach it while driving" storage area under it forward of the seat cushion front? From the other pictures, I gather not, it is a bin. Again, go back to the Gen II with the nice hidden drawer. So hidden in fact, that my sister didn't even know it was there until I told her last week. She has had her Tideland for almost 6 years.
    Now put the climate controls back on the MFD.: 2 big, clear, easy to see button pushes and done, eyes still on the road. And RAISE the MFD back up. The lower it is the farther your eyes are from the road.
    One can only hope the PHEV Prius will have the shifter/console and 'some things back on the MFD' changes. That would make it a more tolerable 'deprovement' from my Gen II compared to the Gen III. It would move the PHEV Prius up on the 'to consider when my 2004 needs to be replaced' list alongside the Leaf.
    WHY does Toyota force you to buy the most expensive model to get 3 door SmartKey?? ARRGGG Same thing with the LED head lights and auto-dimming mirror. There is NO REASON these shouldn't be AT LEAST offered as 'options' on 'lower' models for those that don't want faux leather, bigger wheels and/or navigation.
  20. Offline
    Gurple42 New Member
    Mar 10, 2011
    357
    Santa Monica, Ca.
    Your Vehicle Year:
    Just got my latest edition of "Autoweek". The just got a new Prius v for a one year test. I'll be interested in their experience with the car.:p
Share This Page
