"Problem" message on MFD after installing aftermarket stereo
Discussion in 'Gen 2 Prius Audio and Electronics' started by HippyDippy, May 3, 2012.
  1. HippyDippy
    HippyDippy New Member
    Berkeley
    Hi All,
    Sorry if this has been covered, but i couldn't find anything specific to my problem.
    I installed a new JVC Arsenal KDA735BT CD Receiver in my 2006 Prius. I did the install myself after reading up in this forum and others. It was not my first time doing a stereo install, so I felt confident that I could pull it off. I got the Stereo, wiring harness, Metra ASWC (for steeringwheel functions to work), and in-dash mounting kit all from Crutchfield.
    I couldn't be happier with the install. It works great and only does the random channel/mode change once in a while (I know that I need to open the dash back up and check the ASWC wires to make sure that that there isn't a short)
    This was all done about a month ago, and in the last week I have started to see a "Problem" message on the MFD. Sometimes there will also be the !triangle, sometimes just "problem". At first I only noticed it when driving down a steep hill and braking hard (scary as shit btw), but today it happened on flat ground when not breaking. the road was a little bumpy when it happened and it ocured to me that the road is also bumpy where I had seen the message before.
    After reading on these forums, I checked the battery draw using the method shown here priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html and found that it is a little low, 12.2v on ACC, 11.8v when not charging, 14.3 when charging.
    Could the minor short from the ASWC cause a problem in the battery? Could it just be an old battery since it is still the original? are the numbers I am getting from the battery even low enough to be a concern? Does anyone have any other thoughts as to what might be causing the problem?
    Thanks all!
    I included some shots of the install in process and finished look.
    [edit: removed pic because it had an address shown]
  2. HippyDippy
    Berkeley
    as you can see in lower right corner of the second picture, I used the red inline splicers rather than stripping and wrapping the wires, I think that is why I am getting the shorts.
  3. tdelker
    tdelker Junior Member
    46
    Colorado
    It's unclear to me (but may be clear to others), did the wiring harness have the resistor fix in it?
  4. HippyDippy
    Berkeley
    Sorry, yes, I did use the resistor. You can't see it in this picture. I think that I may have put it in after I took this picture.
