problem with recharging a dead battery
Discussion in 'Honda/Acura Hybrids and EVs' started by deadbattery, Nov 3, 2008.
  1. deadbattery
    deadbattery New Member
    canada
    It's Acura. I left it for over one month without driving. while last night was sub zero but today the temperature is 3 or 4 C. when I tried to drive it, it had no response. I realized the battery was dead!
    I tried to recharge it with a car recharger. A strange clicking sound was heard as soon as the recharger was connected. I double checked everything and tried again. The same thing happened. Then I stopped. Anyone has any idea of what the problem is? frozen battery? any particular problem with the car? Thanks.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    1. how many amps is the charger?
    My charger has 3 setting. 5, 10, and 50 amps. 5 isn't enough with a dead system. 10 seems to work when left sitting for a couple mins.
    It sounds like relays are trying to switch, but there's not enough power. (that's what mine sounds like anyways)
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Try disconnecting one lead on the battery and then charge it, Or both leads and bring it in the house Charge .at least overnight. Then reconnect. What voltage does the Bat read? Is there water in all the cells?
