Production Infiniti M35h sets Guiness world record for Hybrid acceleration
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Rybold, Sep 25, 2011.
  1. Rybold
    Rybold globally warmed member
    2,760
    320
    Southern California
    Infiniti M35h Sets World Hybrid Acceleration Record | Hybrid Cars
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    So we're driving drag racing cars now?
  3. austingreen
    austingreen Senior Member
    13,533
    4,063
    Austin, TX, USA
    No but it is a slap at the lexus gs hybrid that gets worse mileage and less acceleration. When the Porsche 918 comes out it will be the speed demon and mileage champion that no one can afford.
  4. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    So-called "performance hybrids" are for the birds. Why add the extra weight to get higher performance numbers? Perhaps in a straight line you can get a slight boost, but I would reduce the weight and add performance in another way. Lowering the weight would give you the added mileage of the hybrid system in any event. Now let's start talking about cornering....
    Honda tried this business model (performance hybrid Accord) years ago and it was a dismal failure.
  5. Tideland Prius
    16,072
    Not that it's a big deal but they used the 2nd Gen's numbers??
    I thought the GS450h did 0-60 in 5.6 secs? (so add a few tenths for 100km/h), so it's pretty close to the M35h.
  6. hill
    8,070
    They're off by about a second. Whoops! - talk about a day late and a dollar short ... no wonder I couldn't find squat about Mitsu holding hybrid 0-60 best time.
    :p
    [quote] ". . . . . . the BMW 7 Series is able to reach 0-60 mph in 4.7 seconds by using ActiveHybrid, (the) 750Li . . . . . . . . . "[/quote]
    Hybrid Luxury Cars From Lexus - News Technology Automotive
    BMW ActiveHybrid 750Li - Features & Specs - Specifications - BMW North America
    still - not bad.
  7. austingreen
    13,533
    4,063
    Austin, TX, USA
    Probably a few tenths of two very fast cars, nothing you would notice if you weren't driving them back to back. But the inifiniti does get 6mpg combined better fuel economy too.
    .[/QUOTE]
    That was my first thought, but they did say "full" hybrid and this is infiniti.
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    It's nice to see every car manufacturer going hybrid-crazy. I have seen comparisons with the Camry hybrid and the Lexus GS 450h. Powertrains for the Lexus GS 450h was developed for the 2006 MY and the Camry's for the 2007 MY.
    I would like to know the mpg during the performance test of the 2012 M35h's 0-60, and the quarter mile runs. If you get speed without efficiency, What is the point!
    A turbocharged, supercharged or a V8 is can also do this at low MPGs.
  9. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    thank god that 2012 Lexus GS450h gets 12% better economy than M35h under the European cycle, right? :).
    2 people like this.
  10. spwolf
    3,156
    440
    Eastern Europe
    i dont think they would save a lot of weight by pairing it with smaller engine... what are we talking about here? Difference between 270hp V6 and 180hp 4cly in Venza is only 110lbs. And I bet even from that 110lbs, few also go to some standard equipment.
    So you are not going to get some crazy mpg savings based on 3% weight save in smaller engine - in fact, you might get an adverse effect if user then tends to press gas more in lesser powered car.
    So they chose to advertise them as performance, as cost to them is almost the same.
  11. Sergiospl
    3,938
    1,351
    28
    Thank you for posting the Euro cycle mileage info about the new GS 450h, one of my favorites. I initially thought that Lexus would develop a GS 350h using the 2.5 V6 in the IS and the ES 300h would get the 2.5 4 cyl of the HyCam.
  12. spwolf
    3,156
    440
    Eastern Europe
    6.3l/100km info was released @ Frankfurt... I believe old GS450h did 7.9l/100km.
    Quite a change.
  13. Tideland Prius
    16,072
    Well part of it was the change to the Atkinson cycle. The same drop was seen on the RX450h and HiHy midlife update when it switched to the 3.5 litre HSD setup.
  14. Sergiospl
    3,938
    1,351
    28
    So, what is the approximate combined US mileage for the GS 450h with a 6.3 Liters/km. When I use this calculator, I get: 37.34mpg. Thanks!
    CalculateMe.com - Convert Liters Per 100 Kilometers to Miles Per Gallon (US)
  15. Tideland Prius
    16,072
