Programing a "New" keyless remote
Discussion in 'Gen 2 Prius Main Forum' started by firstman, Feb 2, 2009.
  1. firstman
    firstman
    Expand Collapse
    New Member
    I have an 05 Prius base pkg, and lost my original (black emblem) keyless remotes. I bought a new one on Ebay with an(black emblem) uncut key. I got info from Prius chat, on how to program new remotes. I was able to program it to lock and unlock , but can't get it to start the car...Please help!!!!
  2. qbee42
    qbee42
    Expand Collapse
    My other car is a boat
    18,040
    2,981
    Northern Michigan
    You don't program the remotes, you program the car to accept the remotes. You need a Toyota tool to do it, or a high end compatible locksmith system.
    Tom
  3. firepa63
    firepa63
    Expand Collapse
    Former Prius Owner
    1,762
    201
  4. RobH
    RobH
    Expand Collapse
    Senior Member
    1,767
    369
    24
    Sunnyvale, California
    You got the hard part done. Now you have to do the easy part.
    Just keep repeating the 5 step function described in http://priuschat.com/forums/knowled...lly-how-program-non-sks-key-fob-detailed.html
  5. patsparks
    patsparks
    Expand Collapse
    An Aussie perspective
    10,667
    547
    Adelaide South Australia
    You don't need any special tools, you need to get the sequence exactly right.
    1. Insert old fob into slot and remove it 4 times in a row, then insert it a fifth time and leave it in.
    2. Open and close driver door 6 times.
    3. Remove old fob from slot. Car is in fob programming mode at this point.
    4. Insert new fob and leave in the slot for a full minute. Watch the blinking red anti-theft light on the dashboard. When it stops flashing and goes dark, your new fob is all set.
    5. Remove the new fob and you're done. You should test both fobs to be sure they work properly.
    from http://priuschat.com/forums/knowled...lly-how-program-non-sks-key-fob-detailed.html
    A final note, do not touch the brake pedal or anything not mentioned in the instructions. Use a watch and make sure you wait the full minute, even 2 minutes is fine but do not take it out until the light stops flashing. If it is still flashing after 2 minutes the process likely failed, test the new fob and if it didn't work, power up then power down then start again.
  6. QuiGonJohn
    QuiGonJohn
    Expand Collapse
    Junior Member
    78
    Davie, FL
    So can you program a new key FOB to work with SKS? Is that a physically different key FOB?
  7. patsparks
    patsparks
    Expand Collapse
    10,667
    547
    No you can't.
    You can program an SKS car to accept a non SKS fob but the SKS can only be partnered with a virgin fob.
  8. lopezjm2001
    lopezjm2001
    Expand Collapse
    Test guinea pig #9
    1,098
    379
    Sydney Australia
    I did the same for my Australian Prius and followed the instructions using the car's FOB slot and I managed to program it to start the car but could not for remote lock unlock. I think there is a compatibility problem between my Australian Prius and the American FOB.
  9. patsparks
    patsparks
    Expand Collapse
    10,667
    547
    No there isn't, it worked for me. If it doesn't work the first time try again. The sequence is very complex so it is easy to make a mistake like pressing the brake or something. Keep trying, it works.
  10. Mulroney
    Mulroney
    Expand Collapse
    New Member
    Melbourne, Australia
    I am trying to replace a keyless remote for my 2004 Prius
    I can't find one on eBay that will ship to Australia, and in any case they are always used. I found a dealer that sells new for US$129, but I'm not sure it will work.
    The US remote has an extra "panic" button that the Australian model does not have.
    Will this keyless remote work on my car?
  11. MacPriusFan
    MacPriusFan
    Expand Collapse
    Junior Member
    Sydney, Australia
    Sorry I can't provide the answer, but:
    If you remove the backup key , hold the release latch & slide the back cover off the fob you can find the part number. As far as I can tell the US ones have a different number to the Aussie & UK ones.
    Perhaps Patsparks can help as he had success with a US ebay one. I wonder what the part number on that was?
    Cheers
    Macpriusfan
  12. Smileinaz
    Smileinaz
    Expand Collapse
    New Member
    Mesa, Arizona
    Hi,
    I Just purchased a 2008 Prius and only have 1 remote. I am looking to get a 2nd remote but I notice that there seems to be Black logo and Silver Logo FOB's, is there a difference? I have a Silver Logo on mine.
    Thanks TC
    A final note, do not touch the brake pedal or anything not mentioned in the instructions. Use a watch and make sure you wait the full minute, even 2 minutes is fine but do not take it out until the light stops flashing. If it is still flashing after 2 minutes the process likely failed, test the new fob and if it didn't work, power up then power down then start again.[/quote]
  13. jinharry
    jinharry
    Expand Collapse
    New Member
    Check the CR2032 Battery!
    Hi all, I just got a used 2007 Prius and bought a NEW SKS key fob for a Toyota dealer. I went through the programming sequence and was unable to get the remote lock/unlock to program. Finally I checked the battery on the fobs and they were BOTH at 3.01V(old and new). I changed the batteries(new = 3.3V) and everything is fine. It's had to believe that you really do need a FRESH set of batteries to link the FOBs to the car.
  14. rameshupr
    rameshupr
    Expand Collapse
    Junior Member
    Sterling, VA
    Not really. I actually used the steps above 4x fob in slot; 6x door open/close to program a USED SKS fob (I checked the FCCID, it matched mine.) But, the remote and SES functionality (proximity operation) don't work, obviously (or not so obviously).
    Just noticed this is an Aussie thread, so forgive me.
    --r
