For Sale Prototype Mods
Discussion in 'Private Sales' started by cproaudio, Mar 27, 2014.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    You are more than welcome to help me locate the factory plug. The only wires that need to be cut are VSS wire, Brake wire and reverse wire. Depending on the car and the mod, most cars only need to cut 1 or 2 wires. Rest are T-Taps. For PWR mod, there's no wire cutting, only T-Taps. When you have custom work done at stereo shops, installers will cut factory wires if there's no plug and play harness available. They just don't tell you that they've cut wires. It's not something customers wants to hear. In most cases, the install job can't be done without cutting wires, especially alarms. Believe me, I would rather do plug and play but I have yet to source the plugs and pins for plug and play.
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I'm down for TSRCA-R2.1. For a Plug-In Prius. I can even make a install video
  3. evil03
    evil03 Junior Member
    Any update for the v1v or v3v for the Prius c? I hit a 13 pc3 interested in socal
  4. Fong
    Fong Member
    85
    32
    Arizona
    A friend in Japan said there is a plug & play version. It allow you to install up to 4 cameras. You can view front,back and sides. But is not cheap. See images for more info. If you guys need more info, I can call him for Q&A!
    Priusmpg likes this.
  5. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Is it possible to get specs on the camera and compatibility of which systems this can work with. TIA
  6. Fong
    Fong Member
    85
    32
    Arizona
    I know he said is compatibility for the prius for sure. He mention, there is one harness connect to your exist and a splitter for all cameras. What car are you looking to get info?
  7. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    The plugin prius, it has different head unit than the regular prius with back camera, right?
  8. Fong
    Fong Member
    85
    32
    Arizona
    I have no knowledge about PPI type. However, I don't it will be an issue.
  9. cproaudio
    2,401
    758
    CA
    I just received the switches. I'll head down to the plastic fab shop to order the blanks sometime this week.
  10. cproaudio
    2,401
    758
    CA
    I need more testers as I am close to shipping. I'm just waiting for the blank switch fillers from the plastic fab shop. At this point I really don't care if model/trim combo has been selected by someone else. I still have the following available
    2X V1V
    4X TSCRA
    5X PWR mod
    I will no longer be building V1 after the current stock is sold out on PC shop. All those that only require V1 will have to order the V1V. I'm discontinuing V1 because in the end, there's almost no cost difference between V1 and V1V to make. V1 will cost the same as V1V on PC shop.
  11. cproaudio
    2,401
    758
    CA
    The plastic shop has not been working out so I may have to resort to 3D printing. I estimate shipping by end of the month.
  12. cproaudio
    2,401
    758
    CA
    The mods are ready to ship.
