Pumping offroad bike tire with Prius airpump
Discussion in 'Newbie Forum' started by Palulf, Aug 6, 2014.
  1. Palulf
    Palulf Junior Member
    68
    24
    Bergen, Norway
    This is probaply a stupid question, but is it possible to use the reserve tire pump to inflate offroad bike tires? Tires without the car vent, that is. Is there an adapter?
    That would make things a lot easier :)
    iPhone ?
    48,945
    what is a reserve tyre pump?
  3. Palulf
    68
    24
    Bergen, Norway
    Sorry, this is the first car I have owned without a spare tire. It just has an electric air pump that connects to the 12 volt outlet and a spray box with some glue. Maybe it could be used to inflate offroad bike tires too...
    iPhone ?
    48,945
    no spare? is it a plug in prius? anyway, i don't think the hose has a valve connection, it has to go through the goop can?
  5. usnavystgc
    3,159
    988
    Tucson, AZ
    If it is as you say, the pump should easily inflate offroad bike tires.
  6. Palulf
    68
    24
    Bergen, Norway
    No spare. Just a pump :D
    I have not looked. I just asumed there was a normal car vent on the pump. The spray can is a stand alone can though.
    Hmm... I think it must have a normal car vent because sometimes you just want to add some air, not fix it with goop.
    iPhone ?
  7. Palulf
    68
    24
    Bergen, Norway
    I will take a picture.
    iPhone ?
  8. bisco
    48,945
    is it really a 2010 without a spare?
  9. Palulf
    68
    24
    Bergen, Norway
    Pump has ha normal car tire connection.
    So... is there an adapter for the thinner offroad bike tire vent?
    iPhone ?
  10. usnavystgc
    3,159
    988
    Tucson, AZ
    No but, you can get an adapter that screws onto your presta valve (on the bike tire).
    Palulf likes this.
  11. Palulf
    68
    24
    Bergen, Norway
    Haha! Great! Thank you!
    iPhone ?
  12. bisco
    48,945
    is it really a 2010 with no spare?
  13. Palulf
    68
    24
    Bergen, Norway
    Yes, it's European if that matters
  14. bisco
    48,945
    i guess it does, the only prius without spare over here is the pip, starting in 2012. and we cannot use pump without goop.
  15. Palulf
    68
    24
    Bergen, Norway
    I will order the valve adapter and give it a try. As you could see, I have not used the pump for anything yet. Hopefully I am not in for a surprise. I'll follow up with some pictures when the valve arrives. Thak you for your help :D
  16. usnavystgc
    3,159
    988
    Tucson, AZ
    You can buy the adapter in many stores (mostly bike stores). No need to order, just pick one up.
