1. Offline
    gsbeliever New Member
    Start a Conversation
    Mar 7, 2011
    Elmira, NY
    Your Vehicle Year:
    Just picked up my 2009 in April so no winter driving yet. I was recently told that if the Prius wheels start to spin, the engine will drop to an idle. I have a particularly contentious driveway and am now concerned that if I try to make a mad dash up my driveway in the snow and the wheels start spinning, I'm screwed. Backing down my driveway and handling the 90 degree turn halfway down (with a 20' dropoff) has resulted in several wrecker calls to straighten vehicles out before they go over the edge.
    If this is a "feature", can it be turned off? My Prius owning buddy told me to buy the best set of snow tires I can find and hope for the best!
    scott
  2. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,828
    1,032
    Nixa, MO
    Your Vehicle Year:
    The traction control stops the wheel spin, not the engine droping to idle. that said, if the driveway is really bad you need to give consideration to parking at the top of the driveway when snowy/icy weather is anticipated and/or investing in studs and/or snow tires. You will definately have traction issues and there is little way to get around that.
    The traction control cannot, in any practicaly way, be disabled in the gen II.
  3. Offline
    Mar 8, 2008
    10,483
    2,410
    Your Vehicle Year:
    Excellent advice.
  4. Offline
    Mar 7, 2011
    Elmira, NY
    Your Vehicle Year:
    Since my house is at the top of my driveway, it's certainly my intention to park there! The back of my property butts up against suburbia (3 houses) so I may ask one of them for permission to park in their driveway on bad days.
    Thanks for the clarification!
    scott
  5. Online
    Apr 14, 2009
    5,826
    1,614
    Greenwood MS USA
    Your Vehicle Year:
    Wise plan! Advance notification (to all three) may eliminate gunshots, you may wish to call ahead (to the property owner you use) when you need this fall back plan.
    Had you not purchased yet, I would have shown you my 'what kind of owner should NOT own a Prius' post, but at this point it would just be rubbing salt into your wounds.
    1 people like this.
  6. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    Buy a good set of 4 studded snows, I recommend and use General Altimax Arctics. Traction control can be disabled, look up the procedure for placing the car in inspection mode. Try not to spin extremely fast in inspection mode. USE IT AT YOUR OWN RISK. I think you will be impressed with the cats winter performance with good tires.
  7. Offline
    wjtracy Senior Member
    Sep 19, 2006
    2,520
    317
    NOVA
    Your Vehicle Year:
    I never realized this was a "problem" and we've been through 5 winters now. We do have good ice/rain traction tires.
    Quoting F8L on a similar thread:
    Buy better tires and problem solved. Those oem Integritys were pretty horrible. The Prii after 2005 were much improved with reduced traction control sensitivity. [IMG]
  8. Offline
    David Beale Senior Member
    Jul 24, 2006
    3,769
    455
    Edmonton Alberta
    Your Vehicle Year:
    Traction control doesn't "work" without good tyres. Get some good tyres and you may be ok without having to disable traction control.
    BTW, I would NEVER attempt to disable traction control. It just isn't worth risking $5000 to $10,000 damage to get somewhere close.
  9. Offline
    Southern Dad Active Member
    Jun 21, 2011
    328
    196
    Monroe, GA
    Your Vehicle Year:
    When I lived in Rhode Island we had a wicked incline in the driveway from our road which was a four lane state highway. One evening after work, I took a running shot at the hill in my front wheel drive Cadillac. After my first slide down the driveway into the roadway, I rented a bobcat and made a double wide parking place at the bottom of the driveway. I spent $700 for a carport and had a new winter parking spot.
    I can't imagine attempting that driveway without the power of the a V-8 under the hood or 4X4 or both. Dang, I'm glad to be back in Georgia. No snow!
  10. Offline
    Simtronic Member
    Feb 9, 2009
    136
    Surrey, UK
    Your Vehicle Year:
    I am surrounded by hills and in the worst of winter I let the tyre pressure down a few PSI I have not been stuck anywhere yet and have been able to get up hills many others haven't. I run standard M&S michelin tyres 205 50 16 in summer and the winter pair are 205 55 16 this is manly due to cost and availability.
    I would not recommend disabling traction control but I might look it up as an emergency reserve, I have seen the instructions posted many moons ago. I hope this helps
  11. Offline
    5,572
    1,173
    Your Vehicle Year:
    I can't imagine what the power of a V-8 would do on that driveway other than polish the ice even faster.
    Would better tires have helped?
  12. Offline
    Simtronic Member
    Feb 9, 2009
    136
    Surrey, UK
    Your Vehicle Year:
    I managed to resist commenting on the "V8" ice polishing dinosaur but seeing as I am not the first. :)
  13. Offline
    Jul 24, 2006
    3,769
    455
    Edmonton Alberta
    Your Vehicle Year:
    DO NOT let the tyre pressure down for snow or ice. You need good tyre pressure to make the tread clear properly and to make the sipes work properly (remove water).
    IF you slip just before the top of the hill and stop then -maybe- taking a "run" at the hill could help. More likely it will guarantee you will loose control on the way up.
    The 2008 has the "corrected" traction control system and will likely keep trying and crawl up the hill IF the tyres have -some- traction. If they have no traction you won't move. There are no miracles involved in switching traction control on or off. If you switch it off and spin the wheels all you will do is polish the snow into ice, which will yield even less traction than snow.
    The technique most likely to succeed is slight pressure on the accelerator to try to keep the systems from over-reacting to slip. Just enough to make the car crawl. If it won't move with this, park it at the bottom and clear the hill of snow/ice or add sand. Or wait for nature to deal with it.
  14. Offline
    tanglefoot New Member
    Mar 27, 2007
    142
    Colorado
    Your Vehicle Year:
    I agree--keep the tire pressure up. You get more ground pressure with more air pressure. You don't want flotation on snowy roads. That's only for sand or certain off-road situations.
    I do try to keep the traction control from engaging. The traction control on the '07 lets me spin the tires a little faster than the ground without cutting down the power which works well for deep stuff. For a short hill, I'll approach it with a little momentum and then gradually let the pedal up as I reach the top to keep the front tires from breaking loose on the climb.
    I wouldn't disable the traction control. It's there to protect the system.
    Tires do make a world of difference. I have some Hankook Optimo H727's on now and they've made it an amazing snow car. The traction control and ABS very rarely engage these days.
    An option for additional hill climbing traction is to climb the hill in reverse, if you're comfortable with it. That way, the weight transfer of the slope is adding weight to the drive tires (which are now in the back) instead of removing weight. Climbing is the weakness of front-wheel-drive cars because of that weight transfer. The Pri does have limited torque in reverse though, since the engine isn't capable of helping. The forward torque is excellent for crawling through snow--I wouldn't want a V-8.
  15. Offline
    Jun 21, 2011
    328
    196
    Monroe, GA
    Your Vehicle Year:
    Would the V-8 power help? At that time I had two vehicles, a Saturn and a Cadillac. I did find that the weight and power of the Cadillac helped me out in the snow up there. My tires were all weather tires but as I discovered those should have said all weather except snow. Needless to say, I didn't like Rhode Island snow much.
  16. Offline
    Mar 27, 2004
    7,638
    838
    United States
    Your Vehicle Year:
    Good snow tires are a must. Ditto the crawl advice: the Prius drive system makes it impossible to stall the engine, so it is feasible to use minimum accelerations (and thus very low speeds) to avoid breaking tire grip.
  17. Offline
    GrumpyCabbie Senior Member
    Dec 14, 2009
    4,271
    923
    North Yorkshire, UK
    Your Vehicle Year:
    If the guy from Alberta says you need good tyres and advice on how to drive in snow, then I'd listen to him. I believe residents of Edmonton know a thing or two about snow :)
  18. Offline
    djasonw Active Member
    Jul 13, 2004
    821
    45
    Coconut Creek, FL
    Your Vehicle Year:
    I've read that the software (or hardware?) was changed earlier than 2008 (as mentioned before) with regards to wheel spin. I own a 2004 and the TC is very, very sensitive. Since the 2004-2009 Prius have the same engine and virtually other shared components, I'm wondering why the 2004 models (and subsequent model years) can't be updated to reflect the less agressive TC threshold. Anyone venture to take a guess?
  19. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    We don't have to guess. This topic has been discussed before, and the answer is known. TC became less sensitive in 2006, but the firmware changes cannot be applied to the earlier ECUs. You would need to swap the ECU for a newer unit. Whether that is possible I don't know.
    Tom
  20. Offline
    stevemcelroy Active Member
    Jan 25, 2009
    716
    123
    Wallingford, PA
    Your Vehicle Year:
    Last year I visited some friends out in the Berkshires - they live at the top of a very steep and long dirt and gravel driveway. When I got there the driveway had been plowed, but was covered with packed snow and ice - I could not see any of the driveway. I was pleasantly surprised to have absolutely no issues going up or down. At the time I had almost brand new all-season tires - they had been on the car for only 2 months or so.
    Best of luck this winter - I hope that with a good set of tires and extra vigilance you will be just fine.
Share This Page
