question: location of tank for rear window washer fluid
Discussion in 'Gen 2 Prius Main Forum' started by RMunroe, Jun 2, 2005.
  1. RMunroe
    RMunroe New Member
    48
    Can someone tell me the location of the tank for the rear window washer fluid? The manual tells me there is a washer - as if someone wouldn't know, but I can't find the place to add additional fluid.
  2. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    It's the front tank, believe it or not it pumps fluid all the way to the back.
    Daves09prius likes this.
  3. eterry2
    eterry2 New Member
    23
    Houston
    We discovered this today. A friend was helping me to replace a chewed up windshield washing hose. He found the two pumps. He also found the path for the front windshield washing hose. We could not find the path that the hose takes to go from the tank in the front to the back. Does anyone know how this works?
    When my hatchback is open, we cannot see anyway a hose could get to the place it squirts out.
    can anyone help? thanks.
  4. konamonk
    konamonk Junior Member
    Oceanside, CA
    Once the hatch is open, the flex rubber hoses between the hinges are the path to the dispenser.
