1. Online
    xliderider Active Member
    Start a Conversation
    Apr 19, 2012
    914
    163
    Honolulu
    Your Vehicle Year:
    Regarding the Prius' first oil change... I have read all of the debates about whether to leave the oil in the car and just have the dealer change it out at the 10K/1 year service, as this is what Toyota has approved and recommends. Some people feel very strongly about changing the oil out sooner to get out any nasty bits of metal, etc. that can cause wear/damage to new engine parts/surfaces. Still others have said that Toyota puts some kind of additive to help protect the car during the break in period (moly additive?) and that changing out the original oil will remove this protection.
    So I'm thinking of a compromise, just changing the oil filter element to get rid of the filtered out metal shavings and bits, but leave the original oil in and top off with 0w-20.
    My question is, when I remove the oil filter cartridge housing, will the oil drain then stop after the oil in the cartridge housing drains out? Or will oil continue to drain out until a new cartridge is placed into the housing and then screwed back in? I'm guessing that the majority of oil is in the drain pan and that only what is in the filter and cartridge housing will come out if the drain plug is left in the drain pan.
    However, some confirmation would be great. ;) Thanks.
    Also, the car will be inclined back slightly on some Rhino ramps if that makes any difference.
  2. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,347
    670
    Wilmington, NC
    Your Vehicle Year:
    Someone reported on here that the oil filter is just above the oil level in the drain pan. So you should be able to change the oil filter without losing oil in the drain pan. You will need to top off the oil since you will lose the amount that was in the original oil filter.
    xliderider likes this.
  3. Online
    Apr 19, 2012
    914
    163
    Honolulu
    Your Vehicle Year:
    Thanks, that's what I was hoping to hear. (y)
  4. Offline
    yeldogt Member
    Jan 20, 2012
    330
    25
    NE
    Your Vehicle Year:
    Once anything has reached the filter -- it is in the filter .... it is not going to sneak out -- and you are not going to get enough to clog the filter. It was once quite common to change the filter every other oil change -- and actually still is with some power equipment. The oil is more of an issue than the filter. You will be very surprised how clean the oil is at 3k and 5k. But ...if you have any concerns just have the oil changed and enjoy the ride.
  5. Online
    Apr 19, 2012
    914
    163
    Honolulu
    Your Vehicle Year:
    Sounds good, but the filter media is quite small. About the same size as the miniscule filter that Nissan uses for their 3.5L V6. :eek:
    I have more faith in the synthetic oils than the filter media at this time. ;)
  6. Offline
    2,817
    416
    Greater Vancouver, BC, Canada
    Your Vehicle Year:
    It still is the norm with Honda, though most dealerships ignore it: push filter replacement with every oil change.
  7. Offline
    Mike500 Interessen-Gemeinschaft Prius
    Mar 1, 2012
    998
    244
    Upstate, SC
    Your Vehicle Year:
    The price of oil and the oil is cheap.
    I do my own oil change at 3,500 mikes, which my car will reach at the 6 months service interval.
    Then, I'll let the dealer do the one year change, which will probably occure in another 3-4 thousand miles.
    Then, I will wait another year to let the dealer do the 24 month service at about 15,000 miles.
    After thet, I'll de the yearly oil change, with oil and filter.
    I just don't trust leaving the original oil for 8,000 miles, much less; 10,000.
  8. Offline
    yeldogt Member
    Jan 20, 2012
    330
    25
    NE
    Your Vehicle Year:
    Mike500 -- Obviously, do what you feel comfortable ... but the extended interval is well established ..... all should check the condition using the dipstick and change accordingly ..... Years ago everybody changed the coolant every year -- now no one thinks about it.
  9. Offline
    schorert Member
    Apr 18, 2012
    125
    48
    mass
    Your Vehicle Year:
    Oh I'm pretty sure that priuschat will establish a early coolant change interval soon enough...I mean it's just crazy to drive around with factory coolant for more than 25kmi, right?
  10. Offline
    Mar 1, 2012
    998
    244
    Upstate, SC
    Your Vehicle Year:
    Take a bath every Saturday Night, if you want to.
    I prefer to shower, every day or even twice, if necessary.
    Thae same thing goes with changing underwear.
    Clean lasts longer.
  11. Offline
    schorert Member
    Apr 18, 2012
    125
    48
    mass
    Your Vehicle Year:
    You only shower once a day? that's freaking gross man. Do a swab of your underarms and send it for analysis...you may find that the daily showers interval that 99% of americans use is waaaay to long.
  12. Offline
    Mr Incredible Bacon
    Jun 23, 2008
    608
    269
    Neb
    Your Vehicle Year:
    Each of the sides is correct in their own way for the reasons they use to justify it.
    When just a filter is removed you will lose the oil in the filter and any that is in the plumbing above the filter. It isn't very much, it won't siphon any of the sump oil out with it, and it's a good halfway between the two warring factions.
    Change Early Crowd Reasoning - "To remove any particles caused by break-in that may be smaller than the filter can catch but that are larger than particles that cause absolutely no harm. There is an abundance of these particles at break-in compared to normal use."
    Change Per the Manual Crowd Reasoning - "Because that's what Toyota says to do."
  13. Offline
    yeldogt Member
    Jan 20, 2012
    330
    25
    NE
    Your Vehicle Year:
    My first car with an extended change was a 2000 Jaguar ---10k change intervals with regular 5w-30 .....per manual -- held 9qt -- but it was a 4lt supercharged V8 -- Never a problem and it went to about 100k before I got rid of it. This is nothing new and is well proven. I own three cars now that have change intervals of 10k -12k and 15k.
Share This Page
