Quick question about my HV bettery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Abdullah Jordan, Apr 3, 2013.
  1. Abdullah Jordan
    Abdullah Jordan Junior Member
    82
    Amman, Jordan
    Hello there ;
    my car had 116000 mile on it , my brother got a 2009 Gen 2 car for parts , it had a total lose damage and it has only 19000 mile on it !! , yes that is so true , anyway , he Suggest to take the 19000 mile HV battery from it and replace it with mine ( my HV battery dosnt have any problem at all ) but he said to me that its used well (since it had 116000 mile on it) so i said ok , once we replace the batteries i did the healthy test on it by using techstream for sure and that are the results , i need to know if the new battery is accepted , good , or excellent ..... thanks every one
  2. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    The only way to know is checking the capacity of the cells themselves. That involves charging to a known value, discharging at a known rate for a known time, and measuring the leftover charge to see how much capacity was in the cell.
    Keep in mind that a 19000mi 2009 was sold 2008, so 5 years and 19000 miles makes it less than 4000 miles a year. Such a rarely used car could have problems with it just sitting there. Also keep in mind 20000 miles on the equator is much harsher to a battery than 20000 miles on a flat dynometer in an air conditioned climate controlled room.
    So to answer your question, there is no answer with the information you provided.
  3. bwilson4web
    15,405
    Looking at the voltages:
    • 15.47V - minimum block
    • 15.62V - maximum block
    • 0.15V - difference
    As a general rule, anything under 0.3V difference suggests the battery module pairs are OK. But the best test is in operation looking for excessive heat or a voltage sag. You can record the data and export it to a <TAB> delimited file to load it into Excel. Then you can plot looking for any module-pairs that show unusual voltage sags or climbs.
  4. Abdullah Jordan
    82
    Amman, Jordan
  5. Abdullah Jordan
    82
    Amman, Jordan
    thanks seems great Bob , thanks man
