R-134a A/C coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pakhong111, Jul 27, 2014.
  1. pakhong111
    pakhong111 Junior Member
    31
    Can anyone please advise which brand/type of R-134a to use for a 2004 Prius. Does it require a special type of coolant? I've re-charged all of my other cars and would like to do the same with my Prius.
    Thank you very much.
  2. Patrick Wong
    18,199
    6,464
    The refrigerant is not an issue.
    The issue is that the Prius electric compressor oil is a special type which does not conduct electricity. You cannot use any fixtures that have been contaminated with oil from normal air conditioning systems, such as hoses or pressure gauges.
  3. pakhong111
    31
    Patrick, Thank you very much for your quick response on this matter. So it is better to buy a new pressure gauge and use it for the Prius only to add the refrigerant coolant.
  4. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    The correct oil to use is ND11, difficult to obtain and expensive. I have successfully topped up my system without adding oil over a number of years without problems. However the AC technicians here on PC will not recommend this practice.
    John (Britprius)
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Sometimes, somethings are best left to the professionals!
  6. Mike500
    Mike500 Senior Member
    2,593
    763
    That is ONLY if that professional is qualified. I've seen too many who are NOT.
    And, ND11 is not that expensive, here, in the US.
  7. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    However, if one has a leak that is venting enough oil to require additional ND11, then that needs to be fixed first. That is something that a pro shop is best suited for, if they know Prius A/C.
