1. Offline
    cornflakes Junior Member
    Start a Conversation
    Mar 29, 2012
    64
    Redondo Beach
    Your Vehicle Year:
    So once in a while, after I park my car, turn it off, then open my door, the inside of the car would beep, as if I were to leave with the lights still on, except my lights are off. On the MID screen, there are no error messages.
    Sometimes it's one long beep (about 1.5 seconds)
    Occasionally it will be just repeating short beeps.
    Doesn't happen all the time, just once in a while.
    I have no idea what the beeps are. Anyone have any ideas?
  2. Offline
    AWDstylez 500hp to 99hp
    Jun 2, 2012
    66
    38
    Your Vehicle Year:
    One long beep is usually that you left the lights on or something.
    However, I too get the repeated short beeps which is usually what happens if you leave the keys in the car. I'd love to know what it means.
  3. Offline
    orangenerd Junior Member
    Mar 31, 2012
    56
    Lawton
    Your Vehicle Year:
    if you open your door before you turn off the car, it will beep signifying the car door was open when you turned it off. it turns off when the door is closed. Happens to me all the time. not sure about the long beep
  4. Offline
    etobia Member
    Sep 8, 2008
    107
    NEW YORK STATE
    Your Vehicle Year:
    It also beeps if you left the car in drive, left sunroof open. It stays on after you have closed the door (w a lock attempt) it will continue to beep until you undo the situation . The same goes for shutting the door leaving vehicle in drive and unoccupied. Only times it shuts off after a brief period without my doing anything are for things like....
    Lights on, keys not detected, etc. and sunroof open.
  5. Offline
    habaneroC New Member
    Jun 11, 2012
    Redlands, CA
    Your Vehicle Year:
    If you get back in and correct your mistake and turn it off again it will do this also. Invariably, this happens to me when I forgot something.
  6. Offline
    Revan86 Animal nerd and alt car guy
    Jul 19, 2012
    286
    84
    All over northern IL
    Your Vehicle Year:
    Do you have the keyless key? It sounds like the car thinks the key is still inside. Maybe the other key?
  7. Offline
    Jun 11, 2012
    Redlands, CA
    Your Vehicle Year:
    Yes, mine is keyless. I think that is the issue in my case.
  8. Offline
    Jul 19, 2012
    286
    84
    Your Vehicle Year:
    cool easy fix then (y)
  9. Offline
    Mar 29, 2012
    64
    Redondo Beach
    Your Vehicle Year:
    Mine is keyless as well... I'll pay attention to that next time... I think I might also be opening my door just a split second before turning off the car... Haha I get out of my car pretty fast
Share This Page
