1. Offline
    scottwyden new jersey photographer
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    Anyone else having a tailgate rattle?
    I checked the license plate and it's not that
    I checked the tonneau cover and it's not that
  2. Offline
    dfran1 New Member
    Sep 7, 2005
    Message Count:
    89
    17
    MA
    Your Vehicle Year:
    I was in the back seat of my wife's Prius IV 2010 today and heard a rattle that I thought at fist was coming from the outside to only find out it was the passengers rear seat causing it. I opened it and closed it several times and it seemed to have gone away, if it comes back then back to the dealer, at least I know where it is coming from.
    Seat folded down= no rattle
    Seat up = rattle
    2 people like this.
  3. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    I'll give that a try!
  4. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    my rear passenger-sde seat back was squeaking - up and down a few times, all better.
  5. Offline
    dmvp New Member
    Jun 16, 2009
    Message Count:
    337
    43
    Outskirts of Chicago
    Your Vehicle Year:
    I would also suggest you make sure the cover over the rear storage is closed all of the way and locked. Do you have anything in the storage area that could be rattling?
  6. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    I do have stuff in it but its a sweatshirt and grocery bags so nothing that will rattle. They are also locked :) I'm going to test with the seats down this morning.
  7. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    The seat trick may worked!
  8. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    So apparently that did NOT fix the problem. I haven't opened the tailgate or touched anything in the back since my last post and the problem noise has gotten worse.
    It was any big bump that the tailgate rattled (more of a creek) but now it is every small bump too.
  9. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    is it a squeak? Mine has a squeak that I attribute to body flex over the road contruction near my house - worse than dirt roads right now
  10. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    It could be a squeak but sounds more like a creaking door then anything
  11. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    sounds like what mine does.
  12. Offline
    nparker13 New Member
    Jun 6, 2009
    Message Count:
    112
    CT
    Your Vehicle Year:
    I found two things that solved my backseat/cargo rattle.
    First was when I folded the seats down, there was still some plastic stuck in the connection hinge that holds the seat. I doubt this contributed, but I think it helped a little.
    Second and more significant is that if I drive with the cargo cover extended, it rattles. If i retract it, it doesnt rattle at all (except when I have my coffee mug in the coffee holder).
    Hope this helps, it was really bothering me for a while.
    1 people like this.
  13. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    @nparker13
    Thanks for the seat tip. I tried it with the cargo cover removed and it still rattled.
  14. Offline
    martinw New Member
    Jun 8, 2009
    Message Count:
    49
    North Hollywood, CA
    Your Vehicle Year:
    I have the slight rattle too. Haven't figured out where it was coming from, so I'll try the tips above. Thanks.
  15. Offline
    Bobsprius BobPrius
    Jul 23, 2009
    Message Count:
    679
    79
    Buffalo
    Your Vehicle Year:
    Could it be from the storage unit under the carpet area or one of the side compartments (drivers side) in the hatch area not being seated correctly?? If you removed the shade that was my other thought....but you did that one. Check the compartment and tire area to be sure nothing is loose there as well....
    1 people like this.
  16. Offline
    cpatch New Member
    Jul 23, 2009
    Message Count:
    383
    79
    Carlsbad, CA
    Your Vehicle Year:
  17. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    Will do! Great idea!
  18. Offline
    Needacar New Member
    May 8, 2009
    Message Count:
    Kansas City Area
  19. Offline
    Apr 19, 2009
    Message Count:
    342
    New Jersey
    Your Vehicle Year:
    My Prius was in for its first service this weekend. For the tailgate they "put felt under the plastic"
    I only hear rattles on big bumps now.
  20. Offline
    tam85 New Member
    May 10, 2010
    Message Count:
    16
    illinois
    Your Vehicle Year:
    I
    i had the same annoying noise too. the bump stops on the tailgate but they are working fine. could it be the bed bolts? any thoughts? thanks.
    1 people like this.
Share This Page
