Really dumb newbie question . . . .
Discussion in 'Gen 2 Prius Main Forum' started by etawful, Feb 27, 2008.
  1. etawful
    etawful New Member
    50
    Okay . . it was dark when I first drove my Prius home, and I could swear that I didn't see any reflections from the speedometer, etc. in the windshield (keeping in mind that the LCD that displays this projects onto a mirror that you then see.
    Last night, I saw a green outline of the shape of the shroud that covers the mirror.
    Now I have dusted the dash and possibly pushed in on the area where those LCD lights project from . . . did I damage something or push it out of alignment, or is the green outline reflection in the windshield completely normal?
  2. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Depends on a variety of things.
    Cleaner windshield will be more reflective. Cleaner dash might be more reflective. If it is darker outside, the windshield will be more reflective. If your eyes have adjusted more to the darkness the reflection will be more noticeable.
    These are a few of the reasons you might not have noticed it before, but are noticing it now. It is common, and it is unlikely that you damaged anything. You can decrease the brightness of the speedometer with the dial on the dash to the left of the steering wheel. This ought to make it less noticeable. The dimmer only applies when your headlights are on, so the display will still be full brightness during the daytime when the reflection isn't visible.
  3. etawful
    etawful New Member
    50
    Thanks Danny.
    I'll dim it a little :)
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    My vote is that you dusted the dimmer switch into a different position.
  5. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    I've only noticed the windshield reflection at night when I have the dash dimmer in the full 'on' daytime position. I like my dash dim at night anyway, especially if I'm on a country road (lots of those around here) without much ambient or traffic light, so use that dimmer almost every day, full on during the daylight hours, turned way down at night.
  6. Danny Hamilton
    926
    94
    Unless you are driving with your headlights on during the day, there is no need to adjust the dimmer to "full on" during the day. The dimmer only affects the display while the headlights are on.
  7. HardCase
    408
    Kalispell, Montana
    This is true and I was aware of it. I typically just leave my headlights on all the time, especially in the winter here in the dreary, dim and frozen North.
  8. aaf709
    3,862
    2022 Prius Prime
    An alternative to dimming is to get a small piece of felt (or some such material) and decrease the size of the hole over the mirror. This would be on the edge closest to the driver. It won't block off any information, but it does block the glare.
