1. Offline
    WD0AFQ Active Member
    Start a Conversation
    Jul 6, 2012
    503
    107
    Dexter, Mo.
    Your Vehicle Year:
    This is about as non technical as it gets but did not know where to ask. I just installed a 12 volt cigar plug in the front of the rear seat, close to the 12 volt battery. I need 12 volts with the key off. May be one of many I install. Now, are these little push in and pull out "clips" only good for one time use? There are two in the panel that I mounted the plug into. Someone on the forum told me how to get them out, easy enough. Now, how do I get them back in? I have lost the center punch on one already. It fell all the way though and now lives in the seat frame forever. Are these things available anywhere besides the Toyota parts desk? I have never seen these things before.
    Thanks,
    Dan
  2. Offline
    JLee81 Junior Member
    Feb 27, 2012
    58
    Maryland
    Your Vehicle Year:
    If you push the center pin back through so it sticks out the opposite way you will be able to install them then push the pin just until it is flush. I have not seen this style of fastener anywhere either.
  3. Offline
    Jul 6, 2012
    503
    107
    Dexter, Mo.
    Your Vehicle Year:
    Now, to figure out a better way to hold this panel in place. I am no fan of these little push in clips. 100_0289 (Medium).JPG
  4. Offline
    Feb 27, 2012
    58
    Maryland
    Your Vehicle Year:
    Looks good, I may install one too.
    Sent from my SGH-T989 using Tapatalk 2
  5. Offline
    dellrio Im pretty much awesome
    May 30, 2010
    273
    69
    Des Moines, IA
    Your Vehicle Year:
    I have removed this panel several times, so they can be used again - but they seem to be less effective after each use. I plan on just getting a bag of them as well as a bag of the regular push in plugs from the stealership.
Share This Page
