1. Offline
    ph47mf Junior Member
    Start a Conversation
    Nov 7, 2011
    UK
    Your Vehicle Year:
    I have a query which I can’t find an answer to from the local UK forums, I wonder if you guys can help?
    I have a 2006 Prius T-spirit (have Sat Nav but no rear park assist/rear view camera) and I want to buy a cheap and cheerful rear camera (possibly from Ebay) to install on my car. Apart from purchasing the camera, what else do I need? Do I need some sort of adaptor/wires/software upgrades or is it plug and play?
    Some links of where I can buy these things from would be very useful.
    Thanks in advance.
  2. Offline
    Nov 7, 2011
    UK
    Your Vehicle Year:
  3. Offline
    pcdave Junior Member
    Apr 26, 2012
    Scotland
    Your Vehicle Year:
    Had a very similar question and there is a lot of confusing questions and answers due to different models. Mine a 2006 T4 that does not have navigation or the camera but in 2006 the display was changed for that year model in the UK to the higher resolution ones and supposedly if your steering wheel on the T4 has the nav and voice controls then you have the newer display. Now mine does so in theory I should also be able to get the camera and if so desired the nav and retrofit this as plug and play. BUT like yourself looking at pictures of the MFD and the connectors on the rear I did not see any video inputs like the cheap cams on ebay come with but large connectors either 28 or 40 pin and so far no one has a clear answer on the UK forums at least of what on earth we need. :cry:
    From further looking into it basically with yours as you have the navigation you splice it into the harness with the correct live wires etc that goes from your navigation system to the MFD :S
  4. Offline
    michas New Member
    Nov 5, 2012
    Your Vehicle Year:
Share This Page
