Rear Window Defroster
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Unleashd, Jan 30, 2013.
  1. Unleashd
    Unleashd Junior Member
    71
    Oakhill, VA
    Does the rear defroster work only for the larger rear window piece? the one with the wiper? or should it also work for the smaller piece below the center brake light?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Both the top and small lower one
  3. Unleashd
    71
    Oakhill, VA
    Looks like my lower window defroster is not working. How do I go abut troubleshooting this?
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Check the 'heat trace' and see if you can see any spot where it may have been ht with something inside the trunk and left a break in the trace.
