rear wiper blade refil for 2012 Prius v (lowercase v)?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by atebit, May 3, 2015.
  1. atebit
    atebit New Member
    US
    Can anyone tell me the part number for the rear wiper blade refil for a 2012 Prius v (lowercase v for the Prius v wagon) If you know of a good online source for this part, that would be great, too!
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Pretty sure its a standard 11" blade. Its covered in the manual.
    Amazon shows these as a replacement.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,605
    4,464
    Texas Hill Country
    Or you can buy the OEM rubber insert alone, which I did for my 12 v
    Rear Wiper Insert
    TOYOTA OEM 8521412310
    Toyota 03 08 Matrix Wiper Washer Lift Gate Blade Assembly Insert 8521412310 | eBay
    You will note this link shows it compatible for a Prius v while some other listings say it is not. However it is the correct part number for the hatch back wiper.
    The front Left and Right Wiper Inserts
    TOYOTA OEM 8521447061 and 8521447051
    #3 rjparker, May 3, 2015
    Tim Jones and CharlieGulf like this.
  4. Tim Jones
    Tim Jones Senior Member
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    Slight trick to replace the blade but I forgot it......did mine 14 months
    ago.
  5. Air_Boss
    Air_Boss Senior Member
    3,913
    1,068
    New Yawk
    Have to flip up the shroud over the fastening nut, then flip up and detach the blade frame.
    Tim Jones likes this.
