1. Offline
    MaggieMay New Member
    Apr 6, 2009
    Message Count:
    528
    67
    Gloucester, MA
    Your Vehicle Year:
    2 people like this.
  2. Offline
    Glider New Member
    Jul 10, 2009
    Message Count:
    135
    27
    Memphis
    Your Vehicle Year:
    I have a different issue with the rear wiper on my G3 (not covered in the documents cited). The angular sweep seems to be set high so that the bottom third of the pane doesn't get wiped. Is there a quick adjustment, or should I see about warranty work?
    Anyone else have this problem?
    Thanks.
  3. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    Maggie,
    While I may not describe it too well, Jabber showed me a cool little tricj when I picked up my car at the dealership. You can lift the arm up on the Gen 3 rear wiper, if you slide your fingers under the cap where the arm joints, and separate the cover slightly.
    This does not damage the arm at all, and is in fact designed to do just this. Please try that, and let me know what you think. Certainly seems better than it did on the Gen 2 Prius rear wipers.
    1 people like this.
  4. Offline
    Apr 6, 2009
    Message Count:
    528
    67
    Gloucester, MA
    Your Vehicle Year:
    I will try that before I attempt the 'surgery' that was explained in the Gen2 thread where you trim back the bit of the cover that blocks the arm.
    According to that thread, those that did it, did not have the blade lift in a car wash.
    Glider - you're right the wiper doesn't cover much ground and that's been discussed in a number of threads. Many folks never use that wiper because it has little affect on their vision - I'm thinking I'll use more in winter to move snow than now to move rain.
  5. Offline
    DeanFL 2010 owner - 1st Prius
    Apr 13, 2009
    Message Count:
    986
    321
    Leesburg Florida USA
    Your Vehicle Year:
    Great tip (from Jeff/Jabber from IL) - for washing car or cleaning rear window.
    Tried it and took some pics. Simply spread the underneath part of the plastic cover out (the part toward the wiper by the U shape). It will release the latch there and pivot up as shown. Don't be afraid to force the spread a bit while lifting the cover - it will work.
    7 people like this.
  6. Offline
    stream New Member
    May 12, 2008
    Message Count:
    2,526
    394
    Long Island, NY
    Your Vehicle Year:
    I saw your post when I got back from trying this in the garage. It works great--still have the safety catch, and can easily lift up for cleaning. One more improvement from the previous gen! :p
  7. Offline
    Apr 6, 2009
    Message Count:
    528
    67
    Gloucester, MA
    Your Vehicle Year:
    Awesome Dean - thanks! I'd run out and play with it right now but it's pouring rain here. It looked like the previous Gen the cover comes completely off - in your photos it looks like the cover hinges up so you're not juggling/dropping/loosing it . Excellent!
    I retract my contribution to stupid things in the other thread. :)
    Thanks!
  8. Offline
    Glider New Member
    Jul 10, 2009
    Message Count:
    135
    27
    Memphis
    Your Vehicle Year:
    Actually, I'm one of the (minority of?) folks who likes the wiper. It's just that it's set so the bottom and the top of the sweep are both too far counterclockwise (looking from the back of the car). If it could be adjusted to re-position the arm on the shaft, say, 5-10 degrees more clockwise, all should be well.
    I read about how to flip up the cover that allows you to raise the wiper blade, and when you do this, you can see the shaft with a nut at the end holding the wiper arm on. Piece of cake I thought. However, when I unscrewed that nut, the arm did not want to come off and I hesitate to force it. Maybe you need an extraction tool or something. Maybe there's only one position that it can be mounted at.
    This is not a big deal, but I thought someone might know if the rear window's wiper arm can be reoriented and how to do it.
    Thanks.
    - g
  9. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    Yes, this is EXACTLY was I was talking about. I found it to be very useful when hand washing the car.
    I have brought the car through a car wash already, and other than removing the stubby rooftop antenna by hand first, I did nothing else before entering (other than close the windows). Does anyone know if the rear wiper arm is still at risk in a car wash?
  10. Offline
    eglmainz New Member
    Jan 21, 2009
    Message Count:
    887
    137
    Chicagoland, IL
    Your Vehicle Year:
    I too love the rear wiper, however, I am afraid that with two inches of snow on it (as we get all the time in Chicago), that it will block up most of the view through the rear window. (Granted, I park in a garage at home, and a heated one in the office, so this will only happen if out shopping or something).
    If there is a way to adjust the swing a bit, I would love to get it to wipe a bit lower on the glass myself.
  11. Offline
    donee New Member
    Aug 15, 2005
    Message Count:
    2,958
    183
    Chicagoland
    Your Vehicle Year:
    Hi eglmainz,
    I have had the experience of driving home in a 4 inch snow storm. Of course traffic is very slow. And it was that sticky snow. I had 3 inches of snow on top of the Prius arriving at home. Travel speeds were just too slow to blow it off.
    The rear wiper was the only thing that gave any rearward visibilty at all. Where it did not sweep, there was 2 inches of snow.
    2 people like this.
  12. Offline
    PriusRos A Fairly Senior Member
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    Yes, it's true. with the previous generation, the plastic cover came off completely so it was a pain finding somewhere to put it while you're cleaning the window. Now it's hinged.
  13. Offline
    Apr 13, 2009
    Message Count:
    986
    321
    Your Vehicle Year:
    Crank up the rear defroster and hope it keeps up with the snowfall. Nope, I know better - lived many many years in Chicago and Boston. Now in Florida. Won't rub it in. ;)
  14. Offline
    Glider New Member
    Jul 10, 2009
    Message Count:
    135
    27
    Memphis
    Your Vehicle Year:
    Well, I spoke with the dealership's service manager about this. He got a socket wrench to remove the nut on the shaft and a screwdriver to pry off the wiper arm. The nut came off but the arm wouldn't budge (same results that I had gotten at home :rolleyes:). He said that means Toyota doesn't want you to adjust the arm. We'll have to live with this - it's not a big deal - just would be nice to adjust it.
  15. Offline
    djasonw New Member
    Jul 13, 2004
    Message Count:
    812
    Belle Harbor, NY
    Your Vehicle Year:
    Well I decided to revive this thread since the oldest post is only 4 weeks old. I need some help guys. Believe it or not, my 2004 rear wiper is OEM. Never had a need o change it but it is now time. The rubber is separating and its effectiveness if nil. Let me preface by saying I have two left thumbs and it takes me days (not hours) to construct Ikea furniture. Yes, I am a special needs mechanic to put it lightly. I bought the arm with the blade attached (only way they claim to sell it at the dealer I went to). It was $19 with tax. I know how to remove the bottom clip that enables you to raise the wiper close to 90 degrees in relation to the rear glass. I simply can't figure out how to remove the arm/blade assembly. Does it twist? Its gotta be something so simple but I can't figure it out. Any assistance would be most appreciated.
    TIA!!
  16. Offline
    RoyThePriusGuy New Member
    Sep 12, 2009
    Message Count:
    186
    24
    phoenix
    Your Vehicle Year:
    Why is this not posted on the Gen II forum???
Share This Page
