1. Offline
    Mik1 Member
    Start a Conversation
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Yeah, it might not be visible on my dark gray color. I also took the cover of my trunk from inside, and it is definatelly not prewired, so it will be a challenge to pull the wires in case if it will be possible to connect the camera to HU.
  2. Offline
    priusCpilot Member
    Mar 6, 2012
    241
    42
    LA
    Your Vehicle Year:
    Wow pulling out the whole interior to wire it down like Ausi cars will be more then I want to take on unfortunately.
  3. Offline
    vinny1575 Junior Member
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    It's not that difficult. Your looking at 4 screws and a few floor panels.
  4. Offline
    ROLOPR Member
    May 22, 2012
    252
    Puerto Rico
    Your Vehicle Year:
    Vinny any updates?
  5. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    I don't think that it will be too difficult to pull the wires either. It will take some time, bit of a challange in order to make it looking nice but it is doable IMO. As long as the camera works I am happy to do it. Mine should be in my mail box in a day or two.
  6. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    I just got the pins in the mail today. I'm hoping to have some time tomorrow to retry the wiring.
  7. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    I've found some in store, in Altex, hope they will fit.
    D-Sub Female Crimp Pins : CP20S
  8. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Well... I've got my camera today... The first disappointment for today is that the pins I have didn't make any good for me. I desperately need to find something better. However, the good news is that I installed the camera and pulled all the wires down to the HU. It is not as complicated as it seems, and it took about 2 hours to complete. Once I'll find new pins it will take 5-10 minutes to complete. I connected my camera's power to the reverse lights, since the power connectors were probably a foot or foot and a half long. I am happy with the progress so far. I know I probably shouldn't put everything together until I will be positive that everything is ok; however, I just had a huge desire to do something today.
    managerman likes this.
  9. Offline
    May 13, 2010
    86
    Jacksonville, FL
    Your Vehicle Year:
    That looks great. I am not sure if the reverse light wires will work because I noticed that in the camry (and prius) it gives a 12v charge for about 3 minutes when the car starts. Im assuming this is to check for a reverse camera.
    But who knows.
  10. Offline
    Logical Junior Member
    Dec 11, 2003
    82
    22
    St. Louis, Missouri
    Your Vehicle Year:
    when I did the backup camera with the home link mirror install, i used got the power from the reverse lights and it is working just fine.
  11. Offline
    meehow09 New Member
    Feb 22, 2012
    42
    Chicago
    Your Vehicle Year:
    Vinny, did you try the camera wiring yet to the headunit with the new pins?
  12. Offline
    ROLOPR Member
    May 22, 2012
    252
    Puerto Rico
    Your Vehicle Year:
    So far looks great, and what about the license light, works great? affect in something?
  13. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Well... I found a perfect set of the exact crimp pins from the old desktop computer. They perfectly fit into HU connector... but I guess the luck is not on my side... yet. Originally I put two crimp pins, one into terminal 8 (video in) and another into 16 (video ground) of my connector with the power from the reverse light - didn't work out for me. I disconnected the power from the reverse lights and added two more crimp pins into terminals 7 (+12V) and 15 (ground) didn't worked out either. Tried to measure the voltage on the terminal pins ## 7 and 15 didn't see required 12V. Sucks... but so far my camera project is on hold until further investigation.
  14. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    I didn't put the bulb in since I was still testing; however even with one bulb the plate is bright and visible. Didn't notice any priblem driving with one bulb out last night.
  15. Offline
    IMkenNY Junior Member
    Mar 10, 2012
    73
    Tropical Buffalo NY
    Your Vehicle Year:
    Did you feed the head unit with a reverse signal? I noticed on the priusV (camera is standard equipment) has a 12 volt reverse signal input to switch it to the rear camera mode.
    On toyotas TIS the base wiring diagram also show the base 2012 prius liftback with a camera and 12v reverse input even though a reverse camera isnt shipped in the prius 2.
  16. Offline
    AlpacaFarmer87 New Member
    Jun 28, 2012
    Your Vehicle Year:
    The dealer has backup camera options but they are installed not through the nav system but through the rearview mirror. Unfortunately they cost around 1k with installation and everything :/
  17. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    There was one purple wire in terminal #3 and I thought that this wire might be the reverse signal input, but I did not put a separate wire. Any help with wiring diagram or picture of your connector L154 will be highly appreciated.
      File size:
      156 KB
      223
      File size:
      217.9 KB
      214
  18. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Yikes, that's expensive. I hope we can figure something out with our OEM head units.
  19. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Guys... it is finally happened, I was able to get a picture on my HU in reverse position. Here is the picture of the first result. I just made it happened, and I didn't put everything back together yet. Just wanted to share a good news with everyone. Let me finish all this stuff and I will make a full description, how and where to connect.
  20. Online
    xliderider Active Member
    Apr 19, 2012
    860
    153
    Honolulu
    Your Vehicle Year:
    Still, there doesn't seem to be the actual video input from the camera in that screenshot.
    Just curious why all the trouble and expense to get a backup camera working in the c? My wife and I don't ever use the backup camera in our hatchback. We like the dealer installed ultrasonic backup sensor better because of the audible distance alert.
Share This Page
