1. Offline
    Mik1 Member
    Start a Conversation
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    It does looks like you don't have a 12V source on your camera, just 6.5V. If the camera blacks out and sometime you have kinda grayish color on your screen - you need to make sure that you have 12V source. The flow in both diodes is the same and they just make sure that the electricity flows in one direction. The reason why we have two power sources is because the aftermarket cameras are rated for 12V (in most cases); however, HU only gives 6.5V - which is not enough for AM camera and that is why your picture is not clear. HU's power is required to feel the camera and give the signal back to the HU that the camera is installed, the reverse bulb power source is a continuous power source for the camera's operation. That is why on the diagram the flow of both diodes is shown as from the power source to the camera.
  2. Offline
    ianblake Junior Member
    Apr 12, 2012
    52
    PR
    Your Vehicle Year:
    maybe that was the problem need to try again
  3. Offline
    Apr 12, 2012
    52
    PR
    Your Vehicle Year:
    can someone post a picture of the cables connected to the diodes?
  4. Offline
    hur00003 New Member
    May 17, 2012
    23
    Portland Oregon
    Your Vehicle Year:
    I tested the camera before I installed it and the power is running at 12v. It's strange, I installed it on Saturday, and only had the problem on Saturday.
    The picture is crystal clear and has been fun to play around with.
  5. Offline
    Muhahahahaz Member
    Jul 15, 2009
    135
    CA
    Your Vehicle Year:
    Thanks so much! I have a few questions though.
    1. Do I have to solder anything in order to accomplish this? I very much want to avoid that for many reasons... (a) I don't know how, (b) I don't have a soldering iron (probably expensive), and (c) I want everything to be reversible.
    2. Could anyone post a list of everything I need before I start? Things like components, tools, taps, crimp pins, etc. I have do *some* electronics experience, such as building my computer and adding some relatively simple mods to my 2007 Prius (Auto Door Lock, EV Mode, Power Outlet Mod). However, I barely have any tools at all (just some screwdrivers and a tape measure), and there's all sorts of low-level details that I don't have any experience with... :confused:
    Thanks in advance! :)
  6. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Muhahahahaz you don't have to solder if you don't know how, but it will make your job done in better way. Soldering iron is inexpensive, I've got mine from RadioShack for less than 10 dollars and it had tin and all stuff required for work. As an option you can buy a wire glue (soldering glue); however, I've never tried anything like that and don't know how good it is. In any circumstances everything is reversible, since you do not cut any on board wiring.
    As for the list, you can find such info with links in the write up. But in general you need:
    1. Camera (plus extra couple feet [10-12] of wire in order to run the power from the reverse light
    2. Crimp pins
    3. Diodes
    4. Electrical tape
    5. Something to pull the wires (I used trimmer line)
    6. Screwdriver to take the HU out and small pliers to crimp your pins
    7. Needle or something equal to open a small plastic lock on the connector G79 and push the crimped wires (video, power) into their respective locations
    7. Couple of hours of your time
    8. Patience
  7. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    That's Great! Happy that everything worked out for you:)
  8. Offline
    cornflakes Junior Member
    Mar 29, 2012
    64
    Redondo Beach
    Your Vehicle Year:
    How was running the wiring from the back to the front for you guys? Was it relatively pain-free to run the wires cleanly and hide them?
  9. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    All plastic panels and door scuff plates will not take more than 5-10 mins to take off. When you will take the door scuff plates off (I used the driver's side) you will see a wire harness there and that's where I put my wires as well. The most time consuming and difficult part is pulling the wires through the rubber housing in the left upper corner of the trunk door.
  10. Offline
    hur00003 New Member
    May 17, 2012
    23
    Portland Oregon
    Your Vehicle Year:
    Yeah, that last bit with the rubber housing was a pain in the butt... Running the wires from the head unit to the rubber housing took about 5 minutes. Fishing it through that rubber housing took about 45 minutes.
  11. Online
    managerman Prius c and Prius v Nerd
    Mar 12, 2012
    229
    85
    Columbus, OH
    Your Vehicle Year:
    A small piece of coat hanger works wonders to pull wires through the rubber housing.
    -M
  12. Offline
    V-A New Member
    Aug 18, 2012
    Your Vehicle Year:
    Dear Mik1 - don't see the write up. Where is it?
  13. Online
    Mar 12, 2012
    229
    85
    Columbus, OH
    Your Vehicle Year:
    Mik1's write up is on post #110.
    -M
  14. Online
    Mar 12, 2012
    229
    85
    Columbus, OH
    Your Vehicle Year:
    Sorry, I did not take a picture of that...I did follow Mik1's diagram exactly, except I reversed the direction of the diode coming from the back up light 12V.
    -M
  15. Offline
    GoLittlePrius New Member
    Jul 27, 2012
    Your Vehicle Year:
    Any one have any idea if this will work for a 2012 lift back with out navigation. It has the 6.1 screen but no Nav and no backup camera. Thanks any input would be great
  16. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    It will be helpful to see the terminals on the back of your HU. If you have 16 pins G79 (aka L111 for liftback and L37 for V) connector then you can do it. Otherwise I can not say it for sure.
    The rest of the process is the same. It seems that if you have L111 connector the power will be the same on pin #7 i.e. 6.5V+ and in that case if you will go with AM camera you need to source 12V+ power supply to your camera.
  17. Offline
    libmanj Junior Member
    Jun 12, 2012
    84
    Your Vehicle Year:
    I went to test drive a Prius C a week ago at a dealership called Right Toyota in Scottsdale, AZ. I test drove a C4 (Softex still gets too hot in an Arizona summer to be advisable , BTW). The dealer had installed a backup cam in the car! I backed out, and it worked very well.
    I haven't read through this whole thread, but I know it can be done.
  18. Offline
    priusCpilot Member
    Mar 6, 2012
    240
    42
    LA
    Your Vehicle Year:
    W
    Wow really? I don't think they went through the install other guys had to do? More plug in play I would think for the dealer to do it? How much did they charge for that upgrade on the sticker?
  19. Offline
    Jun 12, 2012
    84
    Your Vehicle Year:
    I believe the upgrade cost $600 on the sticker on the door (or $599). I don't know if they'd do it for a Prius bought elsewhere, but one could ask if they could make it out to Scottsdale. I must say that it worked pretty seamlessly.
  20. Online
    Mar 12, 2012
    229
    85
    Columbus, OH
    Your Vehicle Year:
    So does one you install yourself for about $50.00-$75.00...$600.00 seems a bit steep..
    -M
Share This Page
