Recommend a sun visor extension?
Discussion in 'Prius c Accessories and Modifications' started by Tracy, Sep 18, 2012.
  1. Tracy
    Tracy Member
    171
    101
    My daily commute is perfectly situated so that I am always driving with the sun immediately to my left. And the sun is then shining to the left of how far my visor extends (which, as we all know, isn't that far ;-)
    I was looking at sun visor extenders and I haven't found one specifically for the C - is there one? Or has someone purchased one that you are happy with (that seems to go with the car) that you can recommend?
    hcpc and secondspassed like this.
  2. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    I bet a set of visors from an 07-08 Yaris (has extensions) would fit. As I recall, the 09 and above Yaris had side airbags that needed the removal of the extensions (no extensions).
    I guess in retrospect, the extensions are not a good idea if /when the side airbag deploys.
  3. Tracy
    Tracy Member
    171
    101
    [I guess in retrospect, the extensions are not a good idea if /when the side airbag deploys.[/quote]
    Although the likelihood of them deploying probably increases the more time I spend with the sun shining right in my eyes ;-) I'm tempted to tape an index card to the end! :)
    RocMills likes this.
  4. tk1971
    253
    133
    SG Valley, CA
    Well, assuming your interior is gray... here you go:
    Like mentioned in 2nd post... used or new 08 Yaris visor with built in extension.
    GTprii likes this.
  5. Tracy
    Tracy Member
    171
    101
    PERFECT!!!! I will go in search (rather more elegant that duct-taping an index card in place ;-)
  6. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Tracy,
    I have a similar problem... if you get these and they work out for you, please let me know. My next accessory purchase is going to be the C-specific front window heatshield, but after that I'd love to extend the visors.
  7. Tracy
    Tracy Member
    171
    101
    Yup, I'll post when I get them. Our weather just went all cloudy which means it will mostly be cloudy until.....um.....next July? ;-)
  8. col127
    col127 Member
    345
    Illinois
    Did any of you guys ever buy the Yaris sun visors and install in the Prius C? Wanted to make sure it fit before buying - I took off my sun visor off my C tonight and it 'looks' like it would fit - the visor is about 14" just like the one in the pic. However, the clips that attach the visor to the car is different. In the Prius C, it's just a screw - in the Yaris, it looks like a clip... Not sure if there's a hole on the other side so a screw could be put in.
    Thanks for any help!
  9. Tracy
    Tracy Member
    171
    101
    col127, I haven't. Mostly because the sun went away (for the most part) and I probably won't get all bothered by it again until July next year (no kidding). But yes....I'll post if I get them :)
  10. koipond
    koipond Member
    198
    39
    also waiting to hear about this all-important issue. In my case the sun comes in the morning drive above the rear-view-mirror where the windshield is painted with black dots... but the light is still blinding and it's frustrating not to have a visor extension to fill the gap.
  11. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    I've got one coming in the mail right now. I'll let you know as soon as I get it mounted.
    X
  12. col127
    col127 Member
    345
    Illinois
    awesome! look forward to your report!
  13. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    OK, here is an installed Yaris visor. Definitely not a "bolt on". I had to make some serious mods to the mount bracket but it turned out just fine. See pics:
    X
    GTprii and koipond like this.
  14. col127
    col127 Member
    345
    Illinois
    Awesome... What kind of mods did you have to make?
  15. koipond
    koipond Member
    198
    39
    Yeah, can you share some detail about the "mods" you had to make to get them to install?
  16. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    I started a new thread with some details. You must have missed it.
    Here: Drivers Visor with Extension Slider | PriusChat
    X
    GTprii likes this.
  17. koipond
    koipond Member
    198
    39
    Thanks! :)
    GTprii likes this.
  18. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    A piece of black foamcore cardboard and rubber band is working great for me. Highly recommended! Looking for matching grey plastic with good rigidity.
    Friend of Bill W. likes this.
  19. Taphandle1
    Taphandle1 Junior Member
    I found Visormates - sun visor extenders on Amazon!
  20. kenoarto
    395
    Chicago, IL
    repeat post deleted
