recommended inverter / converter coolant for 2007 Prius
Discussion in 'Gen 2 Prius Main Forum' started by George Green, Dec 6, 2012.
  1. George Green
    George Green New Member
    Jamestown , NY
    What are the recommended inverter / converter coolant for 2007 Prius
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Toyota Super Long Life, same as the Engine coolant - available at any Toyota dealer.
    JeffD
  3. George Green
    Jamestown , NY
  4. George Green
    Jamestown , NY
    guess I better check both systems. Getting a few drops on the garage floor. It looks like it is extremely clean . Is that a clue or is either system still suspect ? Thanks , GG
  5. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Both water pumps have been known to fail. The electric water pump for the inverter has been the subject of a recall (check at the dealer to see if it was done on your Prius) and the mechanical pump for the engine coolant is subject to leaks (check for telltale red drips near the pump shaft).
    JeffD
