1. Offline
    JimboK One owner, low mileage
    Start a Conversation
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    I just finished installing the Vais SLX and XM Direct tuner. (Thanks to BobR for telling me about the Vais unit. The radio sounds great, and I've got 16 character display!) When I first started the car after the install, the red triangle appeared. I shut it off and restarted it with the same result. A quick check of the ScanGauge showed no codes. I spent no time with further troubleshooting due to the late hour and chilly temperature.
    For the install, as part of removing the dash piece with the Park button I disconnected an electrical connector on its back side. I assume the wiring for that connector runs to the Park button. I will check that connection tomorrow to make sure I reconnected it securely. The only other connectors I deliberately messed with were for the radio.
    Any other theories as to what might have happened? Thanks in advance for any assistance.
  2. Offline
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    Disregard. The red triangle's gone this morning; went away on its own.
  3. Offline
    Skwyre7 What's the catch?
    Apr 19, 2006
    2,332
    Richmond, Virginia
    Your Vehicle Year:
    Glad to hear everything is working now.
  4. Offline
    dbotello New Member
    Feb 26, 2006
    56
    The Woodlands, Texas
    When I installed my Sirius solution I had the same problem. I freaked out, until I realized that I was checking the system with the door open. I don't normally drive forward with the door open, but seemed to put it in drive while checking out the radio.
    David
  5. Offline
    galaxee mostly benevolent
    Mar 14, 2005
    9,810
    344
    MD
    Your Vehicle Year:
    always restart 3 times before panicking :)
  6. Offline
    bhaynnes New Member
    Jul 14, 2006
    228
    Belmont CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(JimboK @ Dec 31 2006, 07:34 AM) [snapback]368915[/snapback]</div>
    Don't you just love it when they heal like that? :lol:
  7. Offline
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Skwyre7 @ Dec 31 2006, 10:07 PM) [snapback]369139[/snapback]</div>
    Thanks. You would love the sound, too! Oops, shouldn't tempt you. I see you've ordered your ScanGauge. :)
    <div class='quotetop'>QUOTE(dbotello @ Dec 31 2006, 10:48 PM) [snapback]369156[/snapback]</div>
    Yeah, I've done that before. But the door was closed. And that triggers an error message on the MFD, which this did not.
    <div class='quotetop'>QUOTE(galaxee @ Jan 2 2007, 11:32 AM) [snapback]369575[/snapback]</div>
    I've heard that before, but it didn't surface from my subconscious mind at 11:00 pm after working on the job all day and on the car most of the evening. Before I tried starting the car again (the third time) the next morning, I found several reminders during a PC search for possible causes and solutions to my problem.
    BTW, do you or hubby know why that is?
    <div class='quotetop'>QUOTE(bhaynnes @ Jan 2 2007, 12:36 PM) [snapback]369610[/snapback]</div>
    Amen! Divine intervention at its best. Well maybe not its best, but pretty darned good!
  8. Offline
    Apr 19, 2006
    2,332
    Richmond, Virginia
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(JimboK @ Jan 2 2007, 01:02 PM) [snapback]369619[/snapback]</div>
    I will have to check it out sometime. And yep, I ordered the ScanGauge on Friday morning. The newest version has changeable back light colors, so I won't have to deal with the orange. :lol: I'm eagerly awaiting its arrival.
  9. Offline
    Mar 14, 2005
    9,810
    344
    MD
    Your Vehicle Year:
    for double-checking purposes. say you left the gas cap on, etc. basically so the light won't stay on forever for a fluke condition.
Share This Page
