Remote Engine Start for 2010 Toyota Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Kameel, Aug 10, 2009.
  1. royrose
    royrose Senior Member
    1,389
    948
    Foot of Pikes Peak
    This has been discussed several times on the forum and no one has found a way to change this "feature", so we live with it.
  2. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    This question has been asked before so please indulge me. While I have all of you remote starter owners in one place would you tell me the distance/range, in reality, your are getting. With the OEM or after market units.
    Thanks a bunch. (Possible Christmas gift for my cool wife)
  3. rpeek2
    149
    MidwayUSA
  4. rpeek2
    149
    MidwayUSA
    Guess not.:(
  5. elevine
    elevine New Member
    albany ny
    I have tried it - paid $600 for it installed on a new 2010 Prius. It works however i have found it finicky as one user noticed on a previous note. Have to do it twice often or more. Is there a knack that i am missing although i follow directions. My view is if when you press the remote unlock the first time if the light blinks on the car you are close enough to communicate and the remote starter should work although it might not catch t he first time. Does anyone agree with that. By t he way i dont think i am getting much more than 60 ft. Would have liked more.
  6. elevine
    elevine New Member
    albany ny
    have you figured out t he finicky part. My remote is finicky. need to do it several times before it catches. Perhaps one needs the rythym
  7. Creaky
    Creaky Still motorin...
    85
    New York, NY
    From a 10th floor window in an office building to my car parked below on the street, it responds, inconsistently, and only if I hold the remote to underneath my chin pointed upwards to the top of my skull. Trying again from a 7th floor window, I have no problems in starting my car remotely. (Sorry, this is the only metric I have which gives a sense of working range.)
  8. seal2cc
    seal2cc New Member
    52
    Virginia
    Was thinking of doing this but think now I'll pass. Not absolutely needed and sounds like more inconvenience and uncertainty for me, who would be a casual, infrequent user.
  9. elevine
    elevine New Member
    albany ny
    I would say about 60 ft maximum but very inconsistent. The lights always flash consistently with the first two holds but it often just doesnt start. and than a little close and it starts. This is toyotal installed for a price of $600. Response consistency more than anything bothers me.
  10. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    60ft for me using the OEM remote start.
    Soon I will have the Viper Smart Start system that has an unlimited range. I will be able to start the car from anywhere in the world that has cellular coverage. And it will run for as long I set it to run.
  11. Judgeless
    1,821
    255
    Cleveland, OH
    This is not completely true. There are systems that used the second keyfob and keep it in the remote start. They emulate pressing the brake and pushing start. These systems will run for ever and never have a 10 min cut off.
    It will make the immobilizer worthless because the key is always in the car.
  12. elevine
    elevine New Member
    albany ny
    Any tips on inconsistency or does yours start every time if your within range.
  13. rpeek2
    149
    MidwayUSA
    Thanks to all who responded to my initial question on range. I have since installed a Viper system which has a much longer effective range. Further info can be found in the last couple pages on a previous thread:
    [​IMG] Remote Start Doesn't Keep the Car On
  14. Judgeless
    1,821
    255
    Cleveland, OH
    I do not have it yet. The install date is Feb 15th. From what I read it will start the car every time and it will provide feedback that it is started.
    I have auto head lights. I am having it wired so no lights ever come on. The car will start and no one will know its running.
  15. incognito
    incognito Junior Member
    Canada, AB
    You just start the car power with remote control. Car will decide on its own if has to cool (regarding of temperature you adjust) or heat the interior (winter time). In freezing temperature computer will decide if rear window and windsheeld heater has to be on. If you not plugged the electric block heater and the temperature is below
    -15C (Canadian winter) car will not start with remote control (excessive fuel consumption in cold motor). It will start no problem if you enter the Prius and push the power on. I guess there is fuel temperature sensor (they tell me) and it forced you to check the fuel gauge when you starting the power manually.
    It is charging the battery to higher level (using some energy to transfer to heat) so I can use the electric energy while driving. Cost me $600. I use almost every day in winter time. Love it.
  16. Judgeless
    1,821
    255
    Cleveland, OH
    This is the thread were the guy claims the temp is -15C were the remote start does not work.
  17. Savantster
    Savantster Junior Member
    40
    Colorado Springs, CO
    I have a thread ( http://priuschat.com/forums/gen-iii...404-remote-starter-failed-start-too-cold.html ) where we can talk about the cold start problem.
  18. Savantster
    40
    Actually, the remote start has been turning on my rear defrost when it's really cold. I've looked through the window before opening the door and verified it after reading your post. .. what I'm not sure about is if there is a sensor doing it, or if it was because I turned it "on" before shutting off the car when last I used it. -- I will experiment more once I get my car back from the dealer; but you can have the remote start turn on rear defrost..
  19. Judgeless
    1,821
    255
    Cleveland, OH
    I will check today.
  20. Savantster
    40
    I've re-confirmed that both defrosters come on with the remote when it's cold enough. Once I had both set when I turned the car off, the other time I had not set them myself but they both still came on. I think incognito is correct in that there are sensors involved.
