Remote Fob stopped unlocking doors but starts car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius-walla, Jan 30, 2014.
  1. prius-walla
    prius-walla Junior Member
    28
    25
    essex UK
    had a strange issue arise today. used the car this morning and all was well.
    came home this afternoon and clicked the remote fob to unlock the car and..... nothing. no indicator flash and the central locks didnt work.
    thought the battery was gone in the fob so went inside and got the spare fob and tried that. clicked that and again nothing.
    replaced the battery with a new cr2032 battery and nothing, checked the 12v battery via cars diagnostics and a healthy 12.6 and 14.1 outputs. central locking works via the button on the car door. so fuses, motors etc are ok.
    went online and saw the fob reprogram threads. been spending the last 7 hours trying to reprogram the fobs. searching the net and trying any 'new' or different methods suggested.
    i get to the stage where the car locks and unlocks to confirm its in the ADD mode then press the lock and unlock buttons on the fob and get no response from the car. i have tried every single permutation of presses, 1 second , 1.5 second, 2 second, 4 flashes on the red light.. none work
    also tried the extra steps suggested by other members .. still nothing.
    what am i missing?
    what havent i done?
  2. JC91006
    16,468
    8,383
    I've never heard of a Fob needing re-programming. Do they lose their programming? Out of your 2 remotes, do you have 1 that works? Are you sure the replacement batteries are good? I know they are new and not used, but doesn't mean that are good batteries.
  3. prius-walla
    28
    25
    essex UK
    My friend had exactly the same issue a few days ago in his prius. He found the thread on here about reprogramming the fob and that resolved his issue.
    He forwarded the thread to me but it isn't working for me...
    I was saying how odd it was and the very next day it happens to my car
    Yes it's true the new battery could be a dud but both fobs aren't being recognized by the car. I can't surely have 2 batteries or fobs dying on exactly the same day.
  4. JC91006
    16,468
    8,383
    Yes I agree that you shouldn't have 2 dying remotes all together. If both remotes don't function properly, there is another issue. I still can't believe there is a re-programing function???? There must be another issue.
  5. prius-walla
    28
    25
    essex UK
    I thought 12v battery. But that's fine. I believe the reprogramming function is called the 'chicken dance' where you open and close doors to reteach the car to accept the fobs signals and unlock the doors.
    so many videos and tutorials showing how to do it. All very similer. And it seems a very similar process for almost all Toyotas and Lexus cars.
    My fobs start the car fine but won't unlock. apart from reprograming i can't think what else would cause this issue
  6. JC91006
    16,468
    8,383
    do you have the sks smart key? do you have to put the key into the slot to start?
  7. JC91006
    16,468
    8,383
    I thought that "chicken dance" is to make another duplicate key. I didn't think that was a "re-programming" function.
  8. prius-walla
    28
    25
    essex UK
    Whats so frustrating is that in the videos they make it look so easy with little care and it works... Me... Seven hours in the cold and nothing.
  9. prius-walla
    28
    25
    essex UK
    Non SKS keys.
    Ive read several times tonight where people used the chicken dance to regain remote opening when it had stopped
  10. JC91006
    16,468
    8,383
    I've done that "chicken dance" many many times, it's used to duplicate a "new" key. I don't think it has anything to do with re-programming a non-responding key. That's why your 7 hours isn't getting any results.
    I might not be up to date with this....I'm really not aware there is a re-programming function.
  11. prius-walla
    28
    25
    essex UK
    It worked for my friends 2007 t4 just days ago. But I need help as it isn't working for me.
    What am I missing or am I doing something wrong
  12. prius-walla
    28
    25
    essex UK
    Started working by itself this morning. Both fobs operating as normal.
    That was a random episode. Don't know what I can learn from that...
  13. JC91006
    16,468
    8,383
    The only thing I can think of is one of the buttons on your transmitters were stuck, thereby constantly sending a signal. Even if you pressed unlock or lock, it wouldn't register. But this theory would only hold true if you had the transmitter with the stuck button with you the entire time.
  14. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    How certain are you that the 12 V battery is really okay? As a first question, how old is it?
    Our first symptom of a decaying 12 V battery was erratic fob behavior, and of course the battery passed the dealer tests. I replaced it anyway, and am glad I did (and no more fob trouble). If yours is over four years old, I think the folk wisdom here is that you be best off replacing it. Even if it has nothing to do with this problem, it very likely will cause you some mysterious problem as it slowly deteriorate sometime in the future.
  15. bisco
    48,934
    perhaps the government was temporarily beaming some rays in your direction...
  16. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    What if the receiver in the car malfunctioned for a bit of time?
