Remove Rear Armrest (Center)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by manatee108, Mar 17, 2012.
  1. manatee108
    manatee108 New Member
    Washington, D.C.
    In my opinion, the safest position for a car seat is in the center of the back seats. When you have a car seat installed rear-facing you're not supposed to have an armrest that could flip forward and hit your kid in the face.
    Solution: Remove the rear center armrest
    But how exactly? I've not found any good exploded views or procedures, just talk of the other armrest up front.
  2. gliderman
    gliderman Active Member
    751
    223
    I think the experts will disagree with you. That is why the restraint fasteners are behind the driver seat and passenger seat.
    Dont know about the 2012, but if you look below you will see similar threads.
  3. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Have you tried placing the carseat in the center and see if the center armrest falls down? I doubt it. With the carseat pressing on the center armrest, the armrest will not fall down by anymeans. If your assumptions are true, most vehicles won't have any center armrest and I'm talking not for the just prius alone but for a good number of other car manufacturers.
  4. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    Here's the instructions, but I agree with ImeanGreen, you shouldn't have to do it.
  5. CPSDarren
    CPSDarren CPS Technician
    533
    112
    Chicago
    Fold down armrests are not a problem for carseats, even rear-facing ones, unless specified in the vehicle or carseat owner's manual. Generally, you will not find any type of restriction about fold down armrests.
    Some older Evenflo seats did have such a restriction, but Evenflo removed this instruction many years ago.
    Rear-facing seats are inherently very safe, especially in side impacts. While the center seat has shown to offer an advantage in side impacts, this is based on older studies with vehicles made before side impacts were a priority in vehicle or carseat design. With today's vehicles and carseats that have much improved side impact protection, there is little issue placing a rear-facing child restraint in an outboard seating position.
    There are some other reasons to choose center or outboard seats. In Toyotas, you generally cannot use the LATCH position in the center. Plus, the outboard seat tends to be easier for loading and unloading. On the other hand, the center seat generally gives more room for a rear-facing carseat as the back will fit between the front seat backs to some extent.
