1. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    What holds it on? Is it just clips and you simply pull it off? Can you run a small wire behind the cover without interfering with the air bag deployment?
  2. Offline
    rrolff Prius Surgeon
    Aug 19, 2009
    Message Count:
    1,602
    219
    So Cal
    Your Vehicle Year:
    First - disconnect the - battery terminal (someone should put a high-voltage switch in - to make it easy)
    You pull back the door trim stuff that runs around the edge of the A plastic. Then you can pull the A out at that spot - you will pull it out and back a bit - about an two inches - the pillar snaps out and back *but* there is this thing holding it. That *thing* has some weird connector - it needs to be twisted 90 degrees then you then you can pull out the trim...... I used a needle nose, twisted 90, pulled, and all was fine.
    Reassembly is reverse - you need to twist the thing to get it back (not too hard), and plug and tuck.... Lots of room for wires...
    Post #32 has pics http://priuschat.com/forums/gen-iii...-front-dash-tweeter-removal-4.html#post958886
    Oh - please remember to reconnect the battery :cool:
    1 people like this.
  3. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Thanks, should be easy, I''l disarm the air bag via the batt - terminal
  4. Offline
    Fussion101 New Member
    Jul 1, 2009
    Message Count:
    72
    NYC
    Your Vehicle Year:
    will disconnecting the battery terminal reset the trip and mpg info on the MFD?
  5. Offline
    jayvee New Member
    Aug 11, 2009
    Message Count:
    341
    83
    WA
    Your Vehicle Year:
    Yes, and your radio presets too. And maybe some other things I haven't noticed as well.
  6. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    That's all I noticed that I lost, seemed to keep the phone info
  7. Offline
    debbyandbill New Member
    Mar 3, 2010
    Message Count:
    ohio
    Your Vehicle Year:
    Which batter do I need to disconnect? The starting battery? THanks, Bill
  8. Offline
    LeadingEdgeBoomer New Member
    Aug 8, 2009
    Message Count:
    289
    25
    New Mexico
    Your Vehicle Year:
    How about the pillar to the rear of the front doors? I have a post that is in draft pending confirmation of a rattle solved involving that area, but am waiting for a few days to make sure it does not come back. If it does, info about those interior trim pieces would avoid another dealer trip.
    In fact, info about removing any and all interior panels would be useful. Do I need a service manual for that?
Share This Page
