Removing passenger seat, restoring warning lights to normal
Discussion in 'Gen 3 Prius Technical Discussion' started by tiztim, Aug 17, 2014.
  1. tiztim
    tiztim Junior Member
    49
    Chicago
    For practical reasons, I removed my passenger seat this morning. So roomy! Removing the passenger seat, the connections to the seat sensors for occupancy were disconnected at the bottom of the seat cushion. All went well except now the warning light above the glove compartment complains the passenger is not buckled in, also the airbag malfunction light is on.
    Any advice on how to fool my Prius to act normally? Can I restore this by, for example, connecting jumpers at the modular connections or some other simple, clever way?
    2010 gen III Prius.
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Be very careful! There is an airbag in the seat, and static can set it off. Injuries or death are -possible-.
    The airbag malfunction sensing will be difficult to defeat. Perhaps a resistor across those pins of the connectors. Some research will be required to ascertain the value of resistor and which pins are involved. DO NOT short out pins in an attempt to turn off the light! You could damage the airbag systems.
    The seatbelt sensor is looking for a simple short/open. IF you can figure out which pins to connect for this it's a simple fix.
    But again, be very careful as you can damage systems in the car with inappropriate connections. You can access the schematics on the Toyota manual site.
  3. northwichita
    481
    102
    29
    Wichita KS
    kenmce likes this.
    48,962
    how much have your mpg's gone up with the weight reduction? take the back seats out too!(y)
  5. tiztim
    49
    Chicago
    Thanks, David. Since having my head knocked off while removing the seat never occurred to me, I am going to disqualify myself from further work. I was lucky enough to get the seat out and will be satisfied with that. When putting it back in, I'll keep low.
