Removing seat back of passenger seat?
Discussion in 'Gen III 2010+ Prius Main Forum' started by 1415John, Jun 3, 2010.
  1. 1415John
    1415John New Member
    I need to haul some large items in my 2010 Prius, and need to temporarily remove the seat back to front passenger seat. Does any one know how to do this? The dealer quoted me a charge of $100 to de-install, then re-install. Much appreciated!
  2. qbee42
    qbee42 My other car is a boat
    18,044
    2,971
    Northern Michigan
    Folding the seats flat won't work for you?
    Tom
  3. eglmainz
    eglmainz New Member
    887
    138
    Chicagoland, IL
    It will not fit if you simply lower it all the way? For $100, I would rather rent a u-Haul. By me, (in Chicago area), I can rent a full size van or pickup from them for about $20 per day.
    I would not personally pay them to do that, if I could rent something cheaper. If they do end up 'de-installing' the seat, I would ask if you can watch them, so you can do it again if needed.
  4. tumbleweed
    tumbleweed Senior Member
    4,070
    650
    Eastern Oregon
    The front seat backs have airbags in them. It is recommended that you disconnect the 12V battery and wait a minute or so before you unplug the connectors under the seat. Then you can unbolt the whole seat from the floor of the car, two bolts on the front two on the back. The whole seat can then be removed with the back still attached. When you disconnect the battery you lose all the radio presets but everything else seems to come back OK. I had mine out looking for rattles.
    I think it might be easier to find a friend with a pickup or a station wagon. :)
  5. 32kcolors
    32kcolors Senior Member
    5,755
    924
    Redondo Beach, CA
    It'd be cheaper to U-Haul it.
  6. tzh
    tzh Member
    106
    Maryland
    Buy a truck from Carmax, do your thingy and return it within 1 week/200 miles :)
  7. 1415John
    1415John New Member
    Tumbleweed & all that responded...thanks for the input! Take care, J.
  8. tumbleweed
    4,070
    650
    Eastern Oregon
    I forgot to mention one other thing, I believe if you start the car with an airbag unplugged it will give an airbag alarm that must be reset by a dealer.
