1. Offline
    kiwiruss New Member
    Start a Conversation
    Feb 19, 2007
    29
    My 7 year old decided to spray suntan lotion on the sides and headlamps of my car and it was dried on before I discovered it.
    Needless to say I googled and decided to try a toothbrush with DAWN dish washing detergent. This worked pretty well on the paintwork but not the headlights.
    I'm looking at trying he below product for the headlights.
    MeguiarsDirect.com:Heavy Duty Headlight Restoration Kit Heavy Duty Headlight Restoration Kit
    Has anyone got experience with this product?
  2. Offline
    SILVERCwSUN Member
    Jun 18, 2012
    261
    71
    Western North Carolina foothills
    Your Vehicle Year:
    Future auto detailer in the making?:D
    Try using rubbing alcohol and water with a little liquid soap. The alcohol may cut the chemicals in the sunscreen and the soap and water my help clean it off. This may work. Do not use Goobegone or anything caustic as the plastic will cloud up and you will not be happy. You could also call an expert auto detailer if you have a reputable one in your area.
    Hope this helps, Good luck!
  3. Offline
    jabecker driver of Prii since 2005
    Jul 7, 2005
    448
    67
    Portland, Oregon
    Your Vehicle Year:
    Try warm, sudsy water (Dawn works well) with a few drops of ammonia added (just a few).
  4. Offline
    Mr Incredible Effin' Golden
    Jun 23, 2008
    592
    261
    Neb
    Your Vehicle Year:
    I take it the toothbrush put scratches all over your plastic headlight covers. Without looking out it, it would only be a guess, but any of the top three headlight restoral kits would help. Here's a LINK to an article on the subject at AUTOGEEK.Com.
    I'd get a mild kit and do it maybe two or three times. Don't want to rush the fix.
  5. Offline
    strongbad Member
    Oct 19, 2011
    121
    24
    Arroyo Grande, CA
    Your Vehicle Year:
    It depends on the damage done by the suntan lotion. The Meguiars kit is for restoring badly sun damaged lenses. For old clouldy lenses, they'll look a lot better, but for clear new lenses you'll likely be disappointed. Consider it major surgery that should only be used as a last resort.
  6. Offline
    Erikon Active Member
    Dec 5, 2009
    819
    100
    Rochester, NY
    Your Vehicle Year:
    Toothbrush!?! That had to cause more damage than the lotion!
  7. Offline
    jgestar Junior Member
    Apr 25, 2012
    45
    Apex, NC
    Your Vehicle Year:
    A spray suntan lotion also has solvents and propellants in the formula. Those can have an evil effect on clear plastics (insect repellant is even worse). You may have damage that is hard to polish out. Call your insurance agent and see if your coverage will replace the damaged headlamps. That would be easier than trying to repair them.
    Tom
  8. Offline
    kiwiruss New Member
    Feb 19, 2007
    29
    I tried the Dawn mix with water first, but this didn't budge it. I'll try alcohol on the weekend.
    Thanks for all the replies.
  9. Offline
    cmstlist Junior Member
    May 28, 2012
    98
    Vancouver, BC
    Your Vehicle Year:
    Sunscreen contains metal oxide suspensions such as zinc and titanium - these contribute to its opacity. Maybe on a whim try a solution such as CLR which can remove other types of inorganic scum?
  10. Offline
    SILVERCwSUN Member
    Jun 18, 2012
    261
    71
    Your Vehicle Year:
Share This Page
