I know a few have done this - but I can't find details or pics... I want to remove the console below the bridge to add stuff behind it. Also, adding an inverter, I'm thinking about putting a socket to the rear of the assembly (not visible - just in the back of that whole lower thingy) - the plug would not be seen unless you put your head between your knees... For the center console, (between the seats) I also want to play under there... Any help is greatly appreciated as always! Pics are very welcome (and you get bonus points)!!!
This is really very easy, it's like the whole car practically snaps together! Look for the instructions on how to install the Ipod/USB adapter. You'll find them in .pdf format and that should get you started in the right direction. EDIT: Actually I found the document, but I'm having trouble uploading it. But also look for the original ipod adapter instructions as those tell you how to take apart the dash around the radio properly.
Thanks - that helped - USB search... Here's one - not really as clear as I'd like - this covers center console. http://www.longoparts.com/pdf/installation/Prius/PT233-47100.pdf - still looking for the front area under the bridge.,,
