replace 1 or both or all 4?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, May 3, 2015.
  1. tampaite
    tampaite Member
    225
    38
    FL
    Today was a good day!(could have been bad) - had a flat tire driving on the highway at 70mph and was able to pull over to the right shoulder. Replaced the tire with stepney.
    Am posting some pictures of the tire - could you guys tell me if this occurred due to alignment or something else?
    Also, can I just replace 1 front tire(driver side) or do you recommend replacing both the front or all 4 tires.
    The tires all have DOT code of 03 11 meaning they were manufactured in 3rd week of 2011. Not sure how many miles were on them, I have put on 24K miles on the Prius since I bought the car.
    Tire Size: P195 55R16 86V
    #1 tampaite, May 3, 2015
  2. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Wow, glad you're ok! Maybe just a bad tire? Or perhaps you hit something on the road? Definitely should check your other rubber for defects....
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    You are very lucky! I would definitely take it to a Bridgestone dealer for analysis; have them check your other three tires too, like Dino33ca suggested! Please let us know what they say.
  4. fuzzy1
    10,039
    That will depend a lot on the condition of the remaining tires. This one looks like it may have been worn thin on the edge. Any others similarly worn should go. In my climate zone, I would feel no guilt getting rid of anything with tread worn down to less than 4/32".
    If you replace just one, the new one should be moved to the back, rotating the others to put two matching older ones in front. I have replaced a single destroyed tire, but the others had a third the miles of your set, and far better tread than shown in your pictures.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    All four tires need to be replaced AND you need an alignment. Since the inside had abnormal ware.
    It appears you didn't pay attention to the tires condition. That ware didn't happen in a day or two, it took MONTHS to get that way.
    Your using the spare now I assume. 50 MPH is your max speed and the spare is only rated to go a few hundred miles in its lifetime. So replace them now not in a week or two.
  6. tampaite
    tampaite Member
    225
    38
    FL
    Its possible that I did not pay attention to the tires condition.
    Am shopping online for quotes. Can I put a standard tire(185/65-15) on the Touring model(195/55-16)?
  7. Patrick Wong
    18,198
    6,464
    If your question is whether you can install one such tire, the answer is No. If you want to use a standard tire size you must change all four tires and obviously you will also need to buy 15" wheels that fit the Prius and the tires.
  8. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    Definitely replace both front. You might want to check your tire pressure as well.
  9. tampaite
    tampaite Member
    225
    38
    FL
    4 set of Kumho Solus KR21 Size: P185/65R15 is $387 with installation at Kauffman tires.
    4 set of Kumho Ecsta PA31 Size: P195/55R16 is $511 with installation at Kauffman tires.
    Has anyone used 15inch wheels on Touring model?
    With 15inch tires, I can get a higher mileage warranty 86K as opposed to 40K in the same price range.
    #9 tampaite, May 3, 2015
  10. bisco
    48,946
    what is stepney?
  11. tampaite
    tampaite Member
    225
    38
    FL
    stepney is a spare tire.
  12. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    If you have Costco membership, you should get the tires there.
  13. bisco
    48,946
    never heard that before.:)
  14. tampaite
    tampaite Member
    225
    38
    FL
    Sorry, I have BJs and I don't think they do wheel alignment. Will look into Costco membership cost - thanks.
    does anyone recommend or use standard tires on Touring model ?
  15. mikefocke
    3,637
    1,624
    Sanford, NC
    And the wheels cost what? You almost always pay more buying than you get selling so some of the difference in tire cost will be absorbed in the exchange.
    If just replacing, at least 2 and maybe 4 depending on the condition of the best two of the others. You want matching traction on the same axle.
    Also factor in the cost of an alignment. And suspension inspection. That wear isn't normal. If you haven't been rotating the tires or maintaining tire pressures, maybe the other 2 might be OK but it makes a heck of a difference the tread depth and evenness of the contact patch. And we know Tampa gets lots of weather.
    #15 mikefocke, May 3, 2015
  16. drmanny3
    drmanny3 Member
    124
    Orange County, CA
    I did not see enough of the tire to determine if the wear was that uneven. The first picture suggests that it was even wear. It looks like you had a catastrophic failure along the belt line. That is unusual in my experience. Typically the manufacturer will only cover the tire as long as it has 3/32 or more of tread left and the wear is not due to alignment or some other preventable issue like under inflation. You can at least try a dealer of that tire make. Costco is decent because you can drop your car off and they will rotate and balance for free for the life of the tire. You can always have the alignment done elsewhere. Costco also includes free flat repair and covers the tire if it blows out and is still under warranty. Give them a shot. I used to buy my performance tires from tire rack and then have Costco install but they stopped installing any tires other than the ones they sell.
  17. tampaite
    tampaite Member
    225
    38
    FL
    I've decided to replace the front two tires.
    Replacement would be Kumho Solus KH16.which are similar to the existing Bridgestone Turunza EL400 version.
  18. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I hope your back tires aren't in the same shape or close to it.
    That tire looked horrible and it looked like it wasn't in good shape for some time BEFORE that potentially catastrophic failure.
    I know tires are an expense, but before that, they are a real safety issue.
    Tires (and brakes) are two area's where I always recommend doing the MOST you can, not the least.
  19. Mendel Leisk
    38,213
    The rears have negative camber, do they not? In other words: they splay out at the bottom a bit. This will cause the tire to wear out at the inner edge sooner, with correct alignment. And rear camber is not readily adjustable, requires aftermarket shims.
    Separation like that maybe you can get a replacement set at a discount. In any event, I'd get a set of four, if the tread depth on the remainder is similar, they're near knackered.
  20. tampaite
    tampaite Member
    225
    38
    FL
    The tires came with the car and since I purchased(2 yrs ago) have put in about 24K miles on them.
    I check the air pressure regularly but don't think I have balanced or checked alignment since I bought the car. The other three tires look alright to me.
