Replace 2006 batteries, ECU, and/or engine?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid_Tom, Jan 12, 2012.
  1. Hybrid_Tom
    Hybrid_Tom Junior Member
    83
    Houston, TX
    One thing I am glad of is that I have another vehicle to drive while my Prius sat in the garage. Even though it gets 13.5 mpg, it at least gave me time to scour through this and other websites learning more about my Gen II than I ever wanted to know. Before this adventure, I had never done any maintenance on this car myself. I had always taken it to the dealerships for maintenance, or NTB for tires or brakes.
    Now, I will never take it back to a dealership. I will be doing it all myself from here on out. I just do not trust them, and they charge outrageous rates. My wife drives a 2002 Ford E150 full size van. My other vehicle is a 2000 Dodge Dakota 4x4 quad cab. And my Prius is a 2006.
    I learned years ago that you can save lots of money by maintaining your vehicles yourself, and as long as they are reliable and in good condition, they will last a long time. We have money to buy new cars, but we choose to keep our old ones running as best as I can.
    The Internet and this forum have been the best things that can happen to a Prius owner. We have everything at our fingertips plus the experience of all the thousands of fellow Prius owners to help out. There is never a loss of replys on this site, and I personally appreciate all those replys, because they helped me figure out how to do the repairs on my Gen II myself.
    I did not need much support from you guys after I got started, and most of the time only, I only posted updates. But I always knew you were there if I ran into problems.
    Thanks!
  2. Patrick Wong
    18,199
    6,464
    Since you successfully replaced the engine yourself, I would say that your technical capability is greater than perhaps 90% of the individuals who otherwise might work on your car if you chose not to do so.
    2 people like this.
  3. Hybrid_Tom
    83
    Houston, TX
    My thoughts exactly. I am an electrical engineer, but am also mechanically inclined. These past 10 years or do, I realized that I am probably more intelligent than most of those guys and gals that work on anything I own, so I get the tools and books I need, and do most everything myself, on my vehicles or my house.
    I am just not as young and fit as I used to be, and it is getting more difficult to crawl, climb, bend, and fit in most places where I could have got to in my younger years. I am sure many of you are getting there yourselves, too.
  4. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    You can add me to that list tom.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Ditto, but I sure always give it a damn good try!
  6. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    have to chime in here...nice work Hybrid_Tom! Wow, an inspiration to all us DIYers. What was the steering wheel replacement like? I would like to get my steering wheel controls working again (the right side temp buttons are inop). Sounds cheaper to just get a salvage steering wheel, instead of the internal "part" that is non-functioning. I have installed steering wheel controls in fords before ('aftermarket'/factory cruise controls to be exact). Thanks for any insight or pics of that part of your project!
    Curt
  7. Hybrid_Tom
    83
    Houston, TX
    This is my first attempt at posting pictures, so it may take a few trys to get it right.
    The first shows the air bag removed from the steering wheel.
    The next is the steering wheel and clock-spring removed.
    The last shows the steering wheel control buttons removed from the steering wheel.
    I still have my old steering wheel, so I can get better or different photos if you need.
    There have been many posts on changing out the clock spring, so I won't repost them here. You probably won't need to replace it if your controls are not working on just the right side. As you can see from the last picture, the wiring from the right side controls plugs into the circuit board on the left side and the left one then plugs into the clock-spring. If you are lucky, just the wire harness is unplugged or loose from the left controls, that come from the right controls.
    First and foremost - safety. Be sure to disable your batteries at least 30 minutes before attempting to remove the steering wheel air bag.
    You will need a metric steering wheel puller or a metric threaded puller of some type to get the steering wheel off (the first time). I picked up a cheap set at Harbor Freight that worked just fine.
    Let me know what you need help with and I will post just that info and photos. I have seen just the steering controls on the internet for $35, but I managed to get a fully equipped used Prius steering wheel for $75, which was a good deal.
  8. finman
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Thank you so much! I will look into getting just the steering wheel controls. I will keep you in mind when I get to the 'un-install' part. :)Seems fairly straight forward. Will definitely disconnect the 12 volt beforehand.
    Curt
  9. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    Job well done
    Doing major engine overhaul DIY without shop mechanicor dealer svc is awesome.....
  10. Hybrid_Tom
    83
    Houston, TX
    4 people like this.
  11. Patrick Wong
    18,199
    6,464
    Excellent photos! A few comments/questions:
    1. The use of concrete blocks to hold up the car is not considered "safe" so I am glad you did not have problems with a block crumbling while under load.
    2. How many miles on the replacement engine?
    3. I see that you replaced the engine coolant pump and the serpentine drive belt. Did you replace any other parts while you were at it?
    4. When removing the old powertrain, did you first remove the transaxle, and then the engine - or did you remove both together as one large assembly? It appears that you reinstalled the salvage engine/original transaxle as one assembly. Any comments on which is the easier approach?
    5. How many miles have you logged on the car now, after replacing the engine, and what mpg are you realizing?
    6. Any driveability issues?
    7. Have you decided whether your traction battery is good, or does it need to be replaced?
  12. Hybrid_Tom
    83
    Houston, TX
    1. The concrete blocks are the type used for piers under a house's foundation, and are much stronger than the type bought at garden centers.
    2. It's hard to say for sure, but probably about 80k miles on the replacement engine. I inspected the cam shafts and timing chain, they were in good condition. The valve cover and beneath were really clean. I was taking a chance with the engine of unknown background, that hopefully will pay off by lasting a long time. I did check the engine VIN number on the Toyota website for maintenance and found out the dealership had been changing the oil with synthetic, so I know it was taken care of for a while. But if not, I have my old engine that I may attempt to overhaul and learn more about the inner workings of the engine.
    3. Replaced the plugs, PCV valve, oil, oil filter, air filter, transmission fluid, all coolant in inverter and gas engine, serpentine belt and coolant pump as you stated. Also cleaned and replaced CV joint lubrication on both inner CV joints, and put on new CV joint boot clamps (my first time with CV joints as well). I did reuse my old intake manifold an fuel injectors and fuel rail, as the replacement engine fuel line still had some old gas left in it that smelled like it had varnished, and could be dirty. And I knew my old one was working before removing it and had good fuel in it. I also cleaned the manifold and throttle body while it was easy to access. Since I was there, and my old one leaked, I also replaced the rear main seal. Not knowing if this one was bad, I didn't take the chance. The engine had been cleaned, but it looked like the rear main cold have been leaking.
    4. It was all removed as one assembly. Not sure if it would have been easier removing transaxle first, then ICE. It was difficult to balance the assembly level upon removal and installation, as the transaxle/electric motors were much heavier than gas engine and there was not good information available on where to lift the assembly so it would be balanced, along with not having many places to lift from. It was probably easier the way I did it, because I only had to lower one assembly, and did not have to worry about supporting the ICE while the transaxle was being lowered. I also did not want to separate the two units while in the car. I did not know how far the transaxle shaft fit into the dampener, and did not want to pull it at possibly the wrong angle. When on the ground, I found out it takes a little over 1" to separate the ICE from the transaxle.
    5. I have driven it about 250 miles with no drivability issues. I took it in today to have my tires balanced and rotated, and checked front end alignment, and it was still good.
    6. I am averaging around 41 mpg, and very pleased with the results.
    7. At this time, and in my amazement, I feel the HV battery does not need to be replaced. Seems to charge and last better than before, along with great gas mileage. I put the back seat and all interior back together the past couple of days. I could have sworn the battery was going to have to be replaced, after the tests and the way it was driving before the swap. I guess the ICE was the cause of the poor gas mileage after all. The initial root of the problems was the 12 volt battery was bad, causing the HV battery voltage to swing rapidly from charge to discharge and made the HV battery appear to be bad. Surely just my cleaning of the battery jumper bars did not solely make the HV battery good again.
