Replace front brakes and rotors at 43,000 miles??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Frank2013, Dec 3, 2013.
  1. Frank2013
    Frank2013 Junior Member
    I would like to get the opinion of people about the following behavior by a dealer.
    A lady I know has a 2005 Prius with 43,000 miles. She lives in Montreal (the car was bought new in California). She takes it to the Toyota dealer twice a year, to change from summer to winter tires and back, and do other maintenance. She drives about 5,000 miles per year.
    They called her to tell her that she had to change the front breaks (pads and rotors). They said the pads were 90% used up and might not last the winter, and the rotors were rusted and needed to be changed.
    Going through the maintenance invoices, I saw they measured the break pads several times in the past. At 31,000 miles they were at 7 mm, then at 39,000 they measured 5 mm. That was a year ago, and now it's supposed to all gone? Strange.
    By the time she received my advise it was too late to stop the job. I told her that when picking up the car she should ask them for the used pads and rotors. She got there at 4:30 pm, asked to be shown those parts, and was told the mechanic had already left and they would call her the following day (today) to go pick them up. I also told her to ask them how 5 mm cold have been used up in only 4,000 miles. They told her some bs about very fast wear in city driving, and how taxi cabs had to change the front breaks every 20,000 km (about 12,000 miles) !!!.
    I have a very distinct impression this dealer is not being honest. The rotors were always rusted, for years, and it’s hard to see why they had to be changed. Going over the past maintenance invoices, I see they keep performing these expensive "scheduled maintenance" checks about every 5000 miles. This time they came up with quite an expensive job that I believe was probably not necessary. I wonder if anything can be done. Complain to Toyota about this dealer?
    48,987
    i doubt it, you're usually on your own with dealers, i suppose it's worth a go though. it's buyer beware out there, and they love to prey on the innocent and ignorant. being a social sort of country, might canada have some good consumer protection laws that might help her out?
  3. Mendel Leisk
    38,247
    I've found break wear seems to accelerate towards the end. Plus my attitude towards the pads as thickness drops evolves: I start getting nervous if there's only (say) 3 mm left, am inclined to do the deed sooner than later.
    Plus: low mileage in Montreal, winter after winter? Could be partially or completely seized guide pins. Why not just pull a wheel and see for yourself what pad thickness is remaining?
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    An eight year old car in Montreal? I would fully expect the rotors to be rusted and in need of replacement.
    Particularly if the car is parked outdoors overnight.
    Data Daedalus likes this.
  5. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    Mine were replaced at ~55k miles, just before I bought it. New discs and pads.
    On most cars that I have owned I would never see more than 25-30 on pads, but as previously stated, I don't like when the pad gets low. The braking capacity always to be less and less, even though there might be meat still on the pad. I'm the sane with tyres, grip lessens as the thread drops
    Have look see for yourself
  6. Frank2013
    As I understand it, this car uses very little friction braking (only under 7 mph) as most of the braking is used to recharge the battery, so the pads aren’t used. That’s why the disks on all Prius in wet weather are rusted. But that’s normal. I find it very hard to believe that with so little brake use you could go through 5 mm of pads in just 4,000 miles. People report going well above 100,000 miles on the original pads. Nor am I convinced that the disks (rotors) needed changing just because of rust. The car is parked inside a heated garage at night and during working hours. The total brake job was 500 dollars.
  7. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    When used in non-salty conditions and non-commercial use with non-aggressive driving, the Prius pads and rotors will last 100K to 250K miles. Seriously.
    If the lady you know is a speed racer that brakes hard all the time, I could believe it pads being worn out around that time. But keep in mind the majority of non-panic braking in a Prius is regenerative and the friction brakes never even get touched until the speed drops to around 7mph or less and by that point there is very little momentum still needing to be slowed. This is a very different model than all non-hybrids on the road.
    Being in Montreal, there is considerable salt usage on the roads. I think the dealer is fishy because I would expect either clean rotors and worn pads, or rusted rotors and almost-new pads. Having worn pads and rusty rotors? That doesn't make sense. If you are driving like a mad-woman and braking hard all the time, the small amount of surface rust that would appear over night would be scraped off by the friction brakes themselves and wear out the pad as in a normal vehicle.
    If the regenerative braking is used like on most Prii, the surface rust could most definitely grow and become a problem that requires replacement, but then the pads should look great.
    To me this sounds like the old wallet emptying trick. Surprised her invoice didn't include a fee for filling up the blinker fluid.
  8. Tony D
    468
    132
    Dublin, Ireland
    Might be case of just popping the discs and pads off, giving them a good clean and grease the calipers carriers and putting them back together. I do that a couple of times a year on every car I own as it gives me piece of mind as to what condition they are in and that I cuecked them myself
  9. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Be careful you know what you are doing in the Prius. The Prius is never off unless you pull the 12v battery. It is very possible that as you are cleaning greasing the pads, the pistons shoot out of the brake lines as the onboard computer tries to repressurize the system hopefully not into your flesh.
  10. Tony D
    468
    132
    Dublin, Ireland
    Thanks for that. The more I read about the car, the more I realise that it is not the same as most cars
    Good advice, thanks again
  11. Frank2013
    Yes, I find the pad thing incomprehensible, unless the rust itself can cause the pads to wear fast? But they've always been rusted. This woman does not like to drive fast or brake hard at all. Quite the opposite. And I don't understand why rust is suddenly such a problem. Nor do I understand why it cannot be simply scraped off with a lathe. Also fishy that they did not have the parts available and the mechanic had already left at 4:30 pm, at a time of the year when they are super busy because everybody is putting on their winter tires. Really fishy.
  12. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    when I traded in my 2007 Prius, it still had the original brakes on all four wheels
    I think when I did the 95k maintenance, they said it still looked new
  13. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Actual the advice around here is even simpler. Every few months or so, get up to ~40mph (but under 42mph) shift into neutral and then brake moderately hard. This is all you need to scrape the rust off that may accumulate and make the rotors nice and shiny. Shifting to neutral is the key because it disables regenerative braking.
  14. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Rusty rotors can accelerate pad wear, but not likely to the point that they wear out in under 40k on a Prius.
    Could the rotors be rusted enough to require replacement, possibly, due to excessive road salt use.
    Rust serious enough to warrant replacement will typically intrude deeper into the surface than could be cut while remaining within tolerance.
    Most likely scenario is that the brake rotors were rusty enough to at least be suspect, and there is little reason to go through the process without changing the pads at the same time, but we will never know. 40k is certainly early to need brakes on a Prius. My 08 with over 190k still has the originals all the way around!
  15. fuzzy1
    10,045
    This depends strongly on the driver and conditions. Regen braking is limited by the maximum allowed battery charge rate, and will produce only moderate braking at low speed and light braking at higher speeds. 'Normal' drivers doing 'normal' braking will spend a good deal of their braking time above this limit and engage the friction pads, though this can be greatly reduced with a bit of care and foresight.
    That battery limit is roughly 25kW, and differs somewhat on different generations and versions. Full force highway speed braking can exceed 500kW, which must come almost entirely from friction.
  16. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Believe me, I have had rotors rust beyond the point where they can be turned. Rotors that are that rusty will provide poor braking performance.
    And yes, the rust can prematurely wear the pads.
    I'm hoping that you succeed in retrieving the rotors that were taken off.
  17. bisco
    48,987
    my '04 with 95,000 miles when i sold it, was getting close to needing new front pads. it spent 5 winters here and 4 in vermont.
  18. Frank2013
    Still trying to retrieve the used rotors and pads. Dealer has gone silent and is not returning messages today. In the meantime, thank you all for the comments.
  19. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Tony 2K1 was quite correct about the Prius brakes. Under no circumstances try to remove the brake pads without first disconnecting the 12 volt battery, do this before removing a wheel to work on the brakes as this allows time for the backup power supply capacitors to discharge before you get to the pads. The dismantling procedure after this is much the same as any other car with one other difference. Do not undo any hydraulic bleed nipples or lines to push the caliper pistons back in as this again will give problems. Just push them back in. You cannot bleed the brakes in the normal way.
    John (Britprius)
  20. Mendel Leisk
    38,247
    Another precaution I've heard is to (after everything is bolted up) pump the brake pedal several times, to restore pressure, before reconnecting the battery, to avoid the car detecting low brake fluid pressure, lighting a warning light. Don't know how needed this is (or effective), but it couldn't hurt.
