Replaced Ecopia OEM tires with Continental TrueContact
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mathlal, Jul 9, 2014.
  1. mathlal
    mathlal Junior Member
    32
    Québec, Canada
    Hey guys !
    I replaced my 15" OEM Ecopia tires with Continental TrueContact.
    My feeling is that the Continental is superior at every level ... except fuel economy !
    Way more comfortable (rough road up here in Québec), quieter and way better grip !
    I had them on 2 days before leaving for our annual summer trip of 2500 km (1550 miles).
    Last year, I ended up with an average of 5.0 l/100km (47 MPG) with a mix of highway/freeway/villages and this year with the new tires: 5.5 l/100km (42.8 MPG) with a global average speed of 88 km/h (54 MPH) even though I had the cruise control set between 110-120 km/h (68-75 MPH) whenever I could.
    Tires inflated at 3 psi over the recommended pressure.
    Overall, I'm happy !
  2. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    Pretty big drop there, maybe other issues contributed to it? Only you can decide if how they feel is worth the difference. Would probably drive me crazy! ;) Enjoy your new tires!
  3. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Thanks Mathlal. Please keep us posted on them, especially on whether the mileage stays the same or improves.
    Thanks again!
  4. mathlal
    32
    Québec, Canada
    UPDATE #1
    Coming back from vacation, first tank in normal/city driving for us (aka 85% city driving) I hit the same 5.5 l/100km (42.8 MPG).
    Looking at Fuelly, the average for my last 10 regular/city driving fill-ups give me 5.2 l/100km (45.2 MPG).
    So ± a 2.5 MPG drop.
    Again, just for the better handling in corners and wet weather traction, it's way worth it for me ... enough to order the rear sway bar :eek:)
    Note that I drive consciously in NORMAL more (I was a POWER mode adept for months but the wife noted that it was a bit to jerky on start-ups (i.e. from red lights), going back to NORMAL mode, I must say she was right.)
    Having said that I drive with traffic, no pulse and glide for me.
    Cheers !
  5. mathlal
    32
    Québec, Canada
    UPDATE #2
    Went camping last weekend fully loaded, here's what I got:
    - Tire pressure: 4 psi above recommended
    - Speed: Between 90-100 km/h (56-62 MPH)
    - Round trip: 265 km (165 Miles) half highway, half hilly/twisty road
    - Fuel economy: 6.13 l/100km (38.4 MPG)
    wjtracy likes this.
  6. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    WOW. Fully loaded and then some. 38.4 MPG doesn't sound too bad with all the gear you have hanging off the top and out back.
  7. wjtracy
    wjtracy Senior Member
    11,313
    3,588
    Northern VA (NoVA)
    I am probably going to try those too.
    Hard to find but TireRack.com has them.
  8. cipsaz187
    cipsaz187 Member
    147
    42
    At what mileage did you replace the tires?
  9. mathlal
    32
    Québec, Canada
    Around 53 000 km (33 000 miles) but I do have a winter set.
  10. Dxtreme
    Dxtreme New Member
    Denver, CO
    I'm looking forward to buy a set of Continental TrueContact too. My stock Ecopia set is bald on the outer edge after just 32000 miles. I manage to squeeze another 11000 miles out of the set after 2 rotations and left the bald tires at the rear. I hope the TrueContact is good for snow though. Haven't seen any review on snow driving yet.
    Any more update on MPG, mathlal?
  11. mathlal
    32
    Québec, Canada
    Dxtreme,
    I live in Quebec so winter tire set is a must, I won't comment on the TruContact in snow.
    My last tank was 5.42 l/100km or 43.4 MPG which is average considering my global average over 60 000 km (37 000 miles) is 5.8 l/100km or 40.6 MPG including 2 winters.
    Note also that I installed a Thule roof rack with 2 bike racks since August.
  12. Dxtreme
    Dxtreme New Member
    Denver, CO
    Thank you for the update, mathlal!
    My nearly bald tires yield above 60 MPG for now, so probably I will expect a below 50 MPG for the TrueContact set. Ouch! :cry:
  13. Mendel Leisk
    38,242
    The "Ecopia" tire oft mentioned above is likely Ecopia EP20. This is a stock tire choice by Toyota, for good reasons. They're hard to beat for mpg. Decent rolling too, a little noisy when worn is all.
    Michelin Energy Saver A/S is the only one to get much better I think, and they're often out of stock, and a fair bit pricier.
  14. Dxtreme
    Dxtreme New Member
    Denver, CO
    Yep, it's the EP20. The sidewall is a little too soft I think. Every time I cornered, I could feel the car squirmed a little bit which is annoying. I read about the TrueContact that has much better handling capacity though, and also cheaper at 300$ for a set of 4! Scored!
    Check the review on tirerack for the TrueContact.
  15. wjtracy
    11,313
    3,588
    Northern VA (NoVA)
    Where will you plan to get the TrueContacts? TireRack.com seems to be the only place I see them offered.
